Interchange AFM
Sacramento
Has anyone ever tried to use an AFM from a 4runner (late 80's or 90's 6cyl) or 6cyl camry on a 91/92 3fe? I realize the part numbers are different but they are both 6cyl. and in other applications using a MAF from a different year has simply worked, not worked, or increased performance.
Any sueggestions I would appreciate, oh and by the way if you don't know they all look identical but actual toyota numbers are different.
Thanks:cool:
Research Landtank's MAF upgrade. It's only for OBD-II trucks I believe, but you could attempt something similar.
yeah I looked into it and it is only for actual MAF sensors not AFM. When cruising the yard I noticed tones of the 90's 4runners with the same AFM design and thought just maybe it could be a possibility. might be worth the try.
THanks for the input!
whether it is a VAF or MAF AFM they are designed for a certain air flow or engine displacement. So performance gains comes from placing a larger unit on your engine and then offsetting the size difference by augmenting the injector size. This was done very successfully on the older 3.0L supra sixes by using a unit from the 4.0l Lexus V8. That allowed them to pull the 440cc injectors and swap in 550s.
The only unit you could swap in would be the 93/94 VAF. That is not much of a difference so an injector swap is probably out and while the ECU might adapt to it you might be at the max adjustment range.
Thanks for the replies, I was thinking maybe someone had taken the leap of faith on this before but it seems no one has simply because it might just not work. LOL
Thanks again!
