Intake manifold
Roseburg ,Or
Alright guys, another question. I should’ve put everything in one post, but the more I dig into the 40, the more questions I end up having in my quest to find out why it’s running lean.
The bottom portion of the intake manifold on the 74’ looks to have been repaired at some point. No visible crack(s) or repair done to the inside, but the bottom outside portion where the factory exhaust bolted to looks as if someone either did some welding, or at a minimum some grinding. I’ve sprayed this area with starting fluid to see if it’s my source of vacuum leak, but no luck.
I also have a 78’ intake manifold bolted to the stock exhaust manifold. Are there any major differences to prevent me using the 78’ over the 74’? The 78’ appears to be in better shape overall.
Either way, I’ll have the intake/header resurfaced together and have the intake manifold pressure checked for cracks. I can weld them up from there.
As always, thanks for all the advice!
ive put the older style on my 2f several times but never did it the other way around
The 2F manifold is wider, i.e. it moves the carb away from the cyl head. This can lead to a few other problems: air cleaner might not hit carb, possible interference between carb & brake MC. If swapping from a 74 manifold assembly to a 2F manifold assembly, the exhaust is also very different.
Over the years I have run both the early and late intake manifolds, on the old F engine, and on my current 2F. Supposedly there is a slight difference in low end torque between the two, but I didn't measure, and didn't feel the difference. I ended up using the one that had the most vacuum connections in places I needed them.
If you cannot readily see the difference, you may already have a 2F manifold on your engine and not know it.
It is very common to see a 2F manifold welded. OTOH it is very uncommon to see an F manifold welded.
***UPDATE***
I purchased a new timing light that allowed for advance and RPM readings. I had a feeling the timing was off with my cheap light, which it was with the Pertronix installed. Set timing at 12* and lined everything up. Idles great, vacuum back to 18”. Still misses under a load. I double checked the fuel sight glass and the level is at the top of the very bottom steel mark, which seems weird to me because it was only below half way before.
I did a quick redneck rebuild and revved the engine up around 1,500 RPM and stuck my gloved hand over the carb. No change.
Looked again at the bottom of the intake and saw the bolt closest to the bib had oily fuel on it. I put those bolts in when I first suspected a leak and threw on some sealant that was supposed to be fuel resistant. I’ve attached a photo where you can see what appears to be a repair. I put different sealant on only for the sake of seeing if I can find the problem until I have time to pull everything back apart.
Multiple variables : Chinese carb.
