Installing Headers/Emission Controls
I am currently in the process of restoring my 1975 FJ40 and have bought a set of headers. I was wondering if anyone has already done this kind of install and can tell me what's involved. One of my biggest concerns is how the headers seem to replace a lot of stuff (I've seen a few pictures) like the mounting bracket for the carburetor. I didn't get a kit (ie no brackets), it is simply the headers, so what exactly am I supposed to do with the carburetor? Also, my charcoal canister is rusted through and seems useless at this point, but I was hoping that I don't really need it, especially with headers. But if so, what do I do with the hose line coming from the fuel separator to the charcoal canister? Is this ok to just leave "dangling" or do I need to get a new canister? (not too familiar with the whole emission controls as you may have noticed...) Thanks to anyone who can possibly answer any of my questions!
-Eric
Intake and exaust are separate. Carb. is not affected with a header install...
You retain your intake when installing headers...
The charcoal cannister simply vents the gas tank into the engine rather than the outside atmosphere around the truck. If you don't notice the gasoline smell or it doesn't bother you can just leave the vent line dangling. It doesn't have anything to do with the header.
I am working on my 1975, 40, as well, congrats!! It's the last year of smog exemption here in So Cal. As stated before, the exaust manifold seperates from the intake manifold, there are no issues supporting the carb, just bolt it back up. I put headers on mine as well ,as the thermal reactor had some cracks, spend a few extra bucks and get a Downey, or SOR, I cheeped out and went with the cost effective $150.00 MAF, it works fine and doesnt obstruct anything, but getting it bolted up just wasnt a clean set up, had to custom make washers, double gasketed cause I was worried, it's kinda rigged, when it finally cracks, I will replace it, I am going for the complete de smog, have removed the EGR, Air pump and rails, got tied up with work, shpuld have had the carb rebuilt and the dissy changed out by now, I am planning on picking up parts next week, then all of the VSV, vacume lines, computer, igniter will be gone, the only suggestion I would make is leave the canister, with prices for gas at $3.50 p/gal ,burn the vapors instead of venting them to the atmosphere. :cool:
I find that double gaskets are not reliable. I use a factory gasket and run a bead of high temperature orange RTV around the exhaust ports prior to bolting it up. I do not put a bead around the intake ports. One thing you need to confirm is that the flange thickness is the same on the header flange and the intake flange at the step. One of the biggest reasons why leaks occur is that there is a difference in the step height that the manifold bolt presses against. You need to take dial calipers and measure all six pairs to see what you are dealing with. Originally I tried making washers that had a step in them so that the manifold bolt had a parallel surface to press against. It was next to impossible to keep the rotational orientation right. Then I found a very easy solution to this mismatch. I had the seats on the intake manifold filled with a weld of Aluminum and then had the intake manifold surfaced flat. I then took a slotting router bit that would cut the seat with approximately the same radius and set the depth equal to the header flange thickness for that pair and routed a new seat using the flat surface of the manifold as my working surface and the existing half circle that is the clearance for the manifold bolt as the guide. I originally came up with this technique when I had the original intake and exhaust surfaced only to find that all 6 sets of paired flanges had different heights between the intake and exhaust. If people are interested I can take some photos of an intake manifold after welding and a photo of the router bit used.
Edit: The RTV is applied around the exhaust ports of the header and seals against the manifold gasket.
I absolutely agree with all of your statements about the process of installing the headers,grinding washers is a band-aid attempt at correcting an inherent design issue, If you had a couple pics, I would be interested in seeing them, as well as the jig you used to hold the manifold in place while you routed the washer seat, as I said, my manifold is not leaking right now, I am certain it will, or crack, then I will change it out and do a proper install. :cool:
I will post some photos tomorrow or Friday. I have a spare intake manifold that I have already welded up. I will take some before, during and after photos to show you the process and the results.
