Ok, so I just installed my lights! Ian, thanks again for getting this done for us. They look great, and the light intensity looks good, but I will check them out tonight!
Tools needed:
Philips screwdriver
10 mm socket
Dremel with coarse grit bit to file away plastic
A couple of install issues, already discussed with Ian:
1. When you plug in the connectors, they do not lock, with the clip. Also, what this results in, is the two metal prongs inside the connector on the headlamps do not connect to the socket wired to the car. Simple fix - take a Dremel, and shave off 1/8 of an inch from the edge of the
connector on the headlamp. Plug it back in, the clip locks, and all is good. If you want to be extra safe, put some electrical tape around the connector.
2. The stock headlamps have three mounting positions. There are two 1/4" bolts on either side at the bottom, and one on the top by the grill (inside). The new lights do not have the third bolt on the bottom outside, as they are a one piece, so no way of getting to the outside lower bolt anyway. What happens here, is that you can put your fingers in around the edge of the turn signal lens, and the light kinda pulls out, as the two inside bolts act as a pivot. My temporary fix, is to use the top outside mounting tab that lines up with the fender, which is unused on the stock headlamp. I put a 3" bolt through the hole, and now no chance of it pulling out from the indicator light outside edge. I will be looking for some sort of locking pin type fastener, to make this more permanent. Bolt is secure, as the hood closes off any access to it, or will not allow it to pop out. See the third picture.
3. The small parking light goes into the slot at the bottom. Both the Parking light and turn signal fit perfectly. DRL is the headlamp bulb running at a lower pull, and works fine as well. Its all good.........
With all this stuff, I had them both on in 50 minutes, so its really not too much of a hassle, just a few extra steps - took me 10 minutes to decide to file down the connectors! I love the way they look, and I am looking forward to seeing better at night!
View attachment 1091137 View attachment 1091138 View attachment 1091141
