Inline tranny fluid pump
A balanced city
As I wasa driving around today I thought to myself....always scary...Why not plumb in a pump to move the ATF through the system since the tranny is not doing it,,,what diaster could I cause if the pump just moved the fluid really slow??
The tranny shifts fine ans acts normal but there is no fluid movingthrough the syytem so it gets hot..
Any nidea what kind of flow per hour the tranny pumps??
Thanks
The A/T is a hydraulic device, so it has to have fluid pressure to operate. On most A/T’s the pump sucks fluid from the pan, it goes through a pressure regulator, the valve body, torque converter, etc, then all/some of it is sent to the coolers and back to the pan.
The coolers are relatively low pressure, not setup to take full system pressure, so ether some fluid taken from the pump and pressure regulated or it’s sent to the coolers after it’s done it job. I don’t have a hydraulic schematic or ATM manual for the early trans and don’t know how they are setup. If your not pumping fluid externally it could be as simple as in internal line that has fallen off or a connection loose, leaking, stuck pressure relief or diverter valve. To find out your going to need to talk to someone that understands how it’s setup, plumbed and what the failure modes could be. Have you tried emailing Wholesale Automatic Transmissions in Australia?
the ATF never leave sthe pan...never reaching the cooler in teh radiator nor the plate cooler...
If the ATF never left the pan the truck wouldn't move, for the transmission to work, at all, it must have oil pressure. So if it's working, shifting, driving, etc it has internal oil pressure, the oil is being pumped.
Then why would there be no fluid coming out of the cooler lines when I strt the truck with them diconnected?? I was under the same impression, no fluid being pumped no driving, but the truck drives great, just doesnt seem to pump fluid????
Thanks guys....got a follow up email to Rodney right now...just been fighting a hot tranny and when I pull the lines off dont get any flow??? so thought it might be the pump,but now I know thats not the case. There has to be a blockage somewhere cause the truck sure drives good and shifts well, just runs hot......now I am even more stumped...
I don't know if the throw it in reverse at high speed party trick is called for in this situation, but if it is, please have your passenger video tape it and post it to You Tube.
The sudden blast of reverse pressure may unblock your blockage.
Dynosoar:zilla:
If you unplug the in and out lines from your tranny you get no fluid .? ( engine running ? )
you are correct sir...truck running in either park or drive and no fluid pumping out of the lines like I saw on a similiar truck at the tranny shop...so I keep going back to blockage but don't know where since I pushed compressed air through them from the plate cooler, and yes they were disconnected from the tranny at the time...seemed to flow ok..so back to mmmmmmmmmmmmmmmmm..
only place i can think of now is the unions...
you are correct sir...truck running in either park or drive and no fluid pumping out of the lines like I saw on a similiar truck at the tranny shop...so I.
I was refering to those lines ..
main.php
The one on the left it's the inlet and the right ( in the picture disconected ) it's the output .. so if you left like it's pictured and start the engine there is no fluid come from it .?
damn ! But I believe that your tranny need pressure to function .. so it's function right now like a closet tranny without any other cooling than the factory pan .?
Time to spend some quality time with it.
Disconnect both lines at the radiator. Get a short length of clear hose and hose clamps that'll fit the ends of the lines.
Bypass the coolers with the clear hose.
Block the wheels. Put the transfer in neutral. Start the engine and put it in drive.
Check the clear hose. Run it like this for up to 5 minutes.
Then let us know if there's any fluid flow to your cooler.
I'm betting there will be some after a minute or 2.
I think I may have found the issue...wont know for sure till I drive it later but after disconnecting the out put line I got fluid flow, through the elbow. The front cooler line, towards the front of the truck is the output as I was told last night by Rodney.
Went up to the radiator and got major dripage and even some in my mouth :frown: from where it goes into the cooler.
So I then started going from one section to the next...looks like there is some sort of stopage between the radiator cooler which is new and the plate cooler, which is old. So I bypassed the plate cooler and started the truck, the ATF was way down making me believe there was ATF now going places it never has before. Thanks guys for all the help and hope that someone can benifit from my experience.
I will pull the plate cooler and all the lines off after my trip and see what I find...
Pics of what?? I just went from the out side of the radaiator to the return line on the cooler lines...got the tranny down to a high point yesterday of 210...think I was a little down on fluid though...
Where do you found the stopage ..
I haven't found the stopage yet...It is somewhere between the output of the cooler in teh radiator an dthe output of the plate cooler in front...will have answers in a week or so when I return from vactaion..
Ok back from vacation still running hot and still not cooiling properly :frown::frown:
It makes no sense cause the truck runs great and shifts great...gonna drop the pan and try to pull fluid through different sections of line.. hope to find some sort of blockage..thinking there might be something in the hard lines??? It gets some fluid in the lines through the radiator cooler but no pressure??
I replaced both the input and output lines with clear to see flow...will report back next week...
