Back at this again and get good flow or so it appears when I remove the front cooler line…so I reattach the cooler lines and start the truck, I have a clear hose going from the hard line to the cooler in the radiator, get some flow but no pressure. I have bypassed the aux cooler in the front but it still runs hot. I have an aftermarket sender tapped into the union at the output side for the hard cooler lines. I am stumped about the lack of pressure through the cooler lines because the trucks drives and shifts fine. Saw the warning light on the dash so I shut it down, drained the fluid dropped the pan, saw some grit but no meatl shavings on the magnets. I did try adjusting the throttle cable and the truck drives even better now but no change in fluid flow.
