As some of you may have read my other post I have been having an idling issue. At first it was just inconsistent and rough at times. I did a tune up, plugs, wires, distributor cap and rotor. The idling became much worse. I ended up getting code 26. After it warmed up it would run fine and the code would go away. I unplugged the connectors on the 02 sensors and it ran perfect. I installed two oem toyota 02 sensors and the code cleared and it ran great. After 150 miles or so the inconsistent idling came back. I was on trails and went through water when the inconsistent idling came back. My first thought was getting water in the distributor. Once I got back home I checked everything. There was no water in the distributor. I also added electric grease to the wires. I am not sure if the water caused the inconsistent idling or if it was just a coincidence.
Could the 02 sensors have gotten wet and becoming this issue? Shouldn't it have tried out by now? It's been almost a week.
