Inconsistent Idle
Disconnected the 02 sensor closes to the passenger side door. Started the 80 check engine like came on but it ran fine. Looked like there was a some some moisture in there. Sprayed air in there and then added electric grease. Plugged the 02 sensor back in check engine light went off but idled like crap again. I disconnect the 02 sensor again and let the truck run for a little while. Again, check engine light and on but ran great but ran so well you could not even tell it was running. After five minutes or so unturned it off and reconnected the 02 sensor. Stared up and it ran fine. Took it for a drive and ran fine. Not sure why it didn't run fun the first time I reconnected it but it seems to be running good now. Hopefully it was just moisture and cleaning it and adding electrical grease fixed it.
More than likely you will need to pull the EFI fuse to reset the ECM each time you make a change or it will take several start/stop cycles to learn new parameters.
Then why did it work the second time it was replugged in? Don't you need to unplug the efi fuse when theirs a check engine light?
I suggest you read the related sections in the FSM to get a better understanding how the various sensors work in conjuction with the ECM. I'm guessing that when you unplugged the sensors the ECM immediately detected a failure in the heating circuit portion of the O2 sensor and set a DTC then the ECM went into a failure/limp mode. When you reconnected the sensor the heating circuit was working which cleared the DTC and started properly reading the sensor again. You had removed the water from the connector so the sensor was then providing a proper O2 reading. Their are several types of errors the ECM processes, immediately, after a period of time or after "two trips". Some errors are soft errors which reset by themselves or when the ignition is turned off. Others are more permanently stored until manually reset.
I suggest you read the related sections in the FSM to get a better understanding how the various sensors work in conjuction with the ECM. I'm guessing that when you unplugged the sensors the ECM immediately detected a failure in the heating circuit portion of the O2 sensor and set a DTC then the ECM went into a failure/limp mode. When you reconnected the sensor the heating circuit was working which cleared the DTC and started properly reading the sensor again. You had removed the water from the connector so the sensor was then proving a proper O2 reading. Their are several types of errors the ECM processes, immediately, after a period of time or after "two trips". Some errors are soft errors which reset by themselves or when the ignition is turned off. Others are more permanently stored until manually reset.
Gotcha. Makes sense. Thank you!
