Any plans to seal the inside of the engine castings? I.E. paint the insides with glyptal or something else to shed oil and seal any casting sand out of the engine?
Really interesting build RockDoc.
I may have missed it but did you run the new valves through the flow bench? I have seen some interesting comparisons where the added tulip (like the originals) on the valve functioned in smoothing flow transition and keeping a venturi effect; versus increasing the open area at low lift with a really back cut valve like the replacements you have.
I've only gone through one of D Vizards books. Very informative, even if it was about minis.
Cleaned up extremely nice.
Can't wait to see it go back together.
You wheeling in California this summer?
(although Deny made the trip solo as well in 08)I'll have to think a bit on whether I'll coat the chambers or not. I would like to, but would need to rig an oven big enough to handle the head, and I'm not sure 300*F would be good for the valve seals... unless I can figure a way to heat the bottom surface of the head to bake the coatings, but leave the top exposed to cool air to keep from overheating the seals.
Maybe a heat gun and some sort of formed "hotbox" would do the trick, heat up 2 chambers at a time and work along the head.When is this experimental engine going in? You should really dyno your stock engine and then this one to get some good comparable before and after stats.
Looking at your crank i am guessing you have not read Vizards book on modifying pistons rods and cranks.
Not really surprising though i found only four used copies on the web ranging from $139.oo to $201.oo.
I think i might sell my copy!
How did you end up baking the head? half way in the oven, halfway out?
What did you decide about the valve seals?
