I've been trying for 2 nights to get my dash lights to work with no luck. Every time I turn the dimmer switch I blow the fuse (tail) so I hoped it was maybe the switch. I picked up a used one, put it in and same thing happens. Then I started through the wiring diagram and disconnected everything I could find with a RB wire that on my 77 is the dimmed wire from the headlight switch. I pulled the guage panel, the two add on's for aftermarket guages from the PO('s) and still it trips. According to the wiring diagram in my Haynes manual the RB wire comes from the switch and goes to the "combination meter light" (is that the guage cluster?), the "heater control indicator light" (??) and another unmarked lamp in parallel with the heater one. Any ideas where to start looking for the short? I'm stumped and would really like to have gauges at night. Thanks. ....Steve
Anyways, cleaned everything and rewrapped the harness, put it back together and it works like a charm. Thanks for your help. ..Steve
