RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Ok so I bought DEPOs I asked what to replace my existing headlights that was the answer And now I cannot install OE lights or LEDs, I made a video to show the issue, what am I missing here???
h1 and h4 leds will fit? Im losing my entire mind just trying to get the F$#@ing lights to work properlyThe OE bulbs are 9005/6, correct?
The LED bulbs are 9005/6 as well, correct?
Are you sure those Depos are made for those bulbs? It seems as though you need H4 lows and H1 highs.
the deops simply need h4 and H1 leds, I had no clue as my jeep had entirely different lights, new to yotas and I have a monster fj now. so its been a curve LOLI bought the ones you're showing off eBay. They're European and made for a right hand drive(supposedly) and they'll be blinding the oncoming driver if you do get them up and running(just what I've been told). I was looking at the Angel Eyes setup(like 500$) too but haven't bought any yet. My drivers side headlight has a BB hole from the little A-hole neighbor kid but it still works(aside from being so corroded that it's not adjustable). The DEPOs are cool. Please let me know if you get them adapted to American style bulbs or if you find the conversion parts needed.
H4 and h1. The h4 is a dual fillament bulb But the depo's use it for the low beam only.
Honestly I didnt I got so much feedback I got lost in the mix. All I want is headlight that work, this wiring in here looks weak. So Im going to pull the headlights put in the depos and the new harness thanks guysRemember when I mentioned to you the Innovative Harness and H4/H1 bulbs, in the previous video?
The plug you showed in the other video was for the OEM 9006/9005, but the DEPO's require H4/H1 plugs. Innovative makes it easy for plug and play.
I ordered it, Im done pulling my hair out on lights, I got other s*** Id rather be replacing, wiring or otherwise upgrading .LOLThe harness I mentioned above is what I got on my truck. It works perfectly, trulls plug and play. It's possible others may have a similar one, but I have no idea about it. 9006/9005 to H4/H1... that's the one.
Im not looking for ultimate headlight performance, I have rigid s thanks tho, i suck at fiddle ***ing LOLDitch those led bulbs. The light output will be s*** compared to stock because of how LEDs throw light and because their focal point won't be anywhere close to where it needs to be.
I had Depos for a while with halogen bulbs and while the output was less yellow than stock, the pattern wasn't an improvement, so I did a quad bixenon projector retrofit. If you're serious about light, that's the route you should take but I gotta warn you... it is a ton of fiddlefxxxing to make it happen.
