I'm an idiot
Kansas City, Missouri
I hope I'm not the only one to ever do this. I was putting R rear fender flare back on and dropped a 10mm socket down inside the body in front of the rear fender well. Any advise on access? Tried a magnet but can't get around the front of the well far enough. Any wisdom is appreciated, other than don't do that again. Thanks all
Turn the truck up on its side and shake it until the socket falls out.......
Sorry, no real constructive answer.
Small hole saw inside the rocker or pour some Elmer's glue in after it so it doesn't rattle and get another socket.
Seriously. I've done it on customer cars and figured the cost of the socket was less than a comeback for a rattle.
I've got stories.....
Fill the cavity with Mercury. The socket will float out like a cork.
Oh, but there is the cancer, this will most likely give you cancer...
How about one of those magnet-on-a-stick dealies from harbor freight? You can probably bend it up a little to get it into the space, but it should work.
I cannot visualize this easily without looking at my truck, but if I remember correctly, there might be a hole under the rear door plastic trim on the floorboard. I think this is where you can access the body spacer. It might be a little tight to pull the socket out, but if you can see it, you might be able to snake a coat hanger down there and thread the socket and extract it from the rear. This seems like it would be a carnival game at best. Good luck, I had a 12 mm ratcheting end wrench living in my front fender until a recent repair...
I have an 8mm deep with a 6" 1/4 extension sitting between my head and firewall. Dropped it installing new heater hoses last summer. At least I hope its still there when it comes time to pull the engine or head.
I did a similar while moving my washer bottle. The socket fell down between the firewall and inner fender well. A stick with tape on the end worked. I left only the end of the tape (gorilla tape is pretty sticky) sticky so that it didn't get stuck to the side of the fender when pushing it down. It took several tries and a few prayers.
In the future use blue or green masking tape on socket to keep in on extension or ratchet.
Or tie a string to it
A magnet with a thin bendable aluminum shaft, using this has saved me A LOT of extra labor in the past. Unfortunately they do eventually break after lots of uses...
Hahahaha! You said shaft.
Just chiming in to make you feel better. Dropped a head bolt alignment pin down a coolant passage in one of my old hondas and had to pretty much completely disassemble the motor to get it out. Many moons ago, but that experience stuck with me :o
That's funny because I lost a 12mm wrench in the same "black hole". Ended up selling the 80 with my wrench still stuck in there.
To the OP, I would forget about it , buy a new socket and get on with life. If it rattles then deal with it.
I FOUND a 10MM socket on the frame rail of my 80 when I was doing recent work. You can have it if you want......
Lots of great ideas here.
I dropped a push rod into the lifter tray area on a freshly built Chev. 350 while adjusting the valves. It took me 4 hours with two separate magnets on a stick to get it out. I feel your pain.
I think I will vote for the Gorilla tape on a stick (or bendable aluminum rod) A magnet may stick to everything you don't want.
Did the same thing working on the PHH, 2 years later when i pulled the motor, I got my wrench back. For the record it helps to tie the wrench to your wrist with some string, then when you drop it you just reel it back in.
Just chiming in to make you feel better. Dropped a head bolt alignment pin down a coolant passage in one of my old hondas and had to pretty much completely disassemble the motor to get it out. Many moons ago, but that experience stuck with me :eek:
Mission accomplished. That totally makes me feel better!
Lots of great ideas. I'm not worried about the socket, I have lots of those. Just don't want it rattling around. I like the "tape on a stick" idea. My telescoping magnet didn't work as it stuck to everything and couldn't make the bend. My flexible grabber makes the bend but isn't long enough or strong enough to get the job done, (insert joke here-see previous shaft comment).
