IH8WIRING switches.
TN
This is the solution:
Old post:
I'm trying to wire in some rear defrost/demister switches for my front and rear fog lights and could use some help. I had scion switches working properly but decided to upgrade to the rear defrost switches so I'd have an "on" indicator light. I used the scion switches for the garage door mod.
I have an electrical manual but am having difficulty figuring out what goes where.
The info im using is on page 138 of the electrical manual and is also in post 5 of this thread:rear demister/defogger switch wiring diagram
Pin 1 has a green wire
Pin 2 yellow
Pin 3 white with a black stripe
Pin 4 white with a green stripe
Pin 5 unused
Pin 6 blue with an orange stripe
I'm thinking pin 1 and 4 are for switch illumination when headlights are on and just need to be spliced into matching wires of the rheostat.
Pin 3 goes to ground
Pin 2 and 4 to the relay?
I can get either the fog light to turn on or the indicator light to turn on but not both at the same time.
The scion switches didn't have an extra ground wire like these do.
Any ideas?
Thanks
ERG80
I found someone with some parts rigs. He happened to have 2 of them with the harnesses.
I switched the fog light labels from the Scion switches with the defrost labels on these switches.
Sorry, I can't help without probing the wires myself with a meter, but where did you get those switches?
I remember hunting for them a while back, but couldn't find them with the harness attached, so I used 4-Runner switches instead :meh:
ERG80,
Try this wiring diagram through your pic. See if you can get power and light.
Thanks for the diagram 4x4CPOSEADOG but it still gave me the same problem.
I ended getting the result i wanted by sending the
PIN 6 wire (blue with orange stripe) and PIN 3 wire (White with black stripe) to the fog lights. Then the PIN 2 wire (yellow) and PIN 4 wire (white with green stripe) to the rheostat's white with green wire. Then PIN 1 wire (green) to the rheostat's green wire.
IH8Wiring
ERG80
ERG80,
IH8Wiring
ERG80
Congrats, at least you finally figured it out:wrench: Good job though:cheers: So now the switch lights up when you turn on the dash light, right? Then the amber light is on when switch is press in to turn on the foglights, correct?
Thanks.
You're correct. They illuminate with all the other dash switches when the headlights are on and dim with the rheostat like the others. The amber light turns on when the fogs are on.
I didn't think to check if the amber light dims with the rheostat since they're wired into it. hope not...
