Ignition upgrades
Not necessary. The stock ignition is setup great and far more powerful than necessary. If you're getting those symptoms it may be time to change your spark plugs, wires, cap, and rotor at the very least, and maybe double check to make sure your ignition timing is set correctly. Also may be worth checking for vacuum leaks, checking the PCV valve.
x2
"Upgrading" your ignition system will likely cause all sorts of problems. The stock setup is extremely well designed and more than powerful enough for any purpose. There's folks in the middle east pushing 1k HP with mostly stock setups.
