Ignition issues...
Western, MT
Here's the run down... put a 75 2f into a 72 40... have a brand new coil (from Marks offroad) but now need an ignition...desmogged engine with original aisin(sp?) carb...
Do I spend the $340 sor wants for the ignitor?
Do I convert to HEI ignition? Yes I have read the past posts and used the search function...
Do I also need the ballast resistor?
Also two wires with green plugs coming out of the carb... one is the idle silinoid I think... do these need to be hooked up and to what?
Also, where to source longer brake lines...
Thanks for the help!
I guess it may be a 78 2F
Talked to CDan and found out ballast and ignitor are no longer made...suggested talking to urban land cruisers...problem solved...
If you need complete ignition, consider finding a small-cap distributor and matching ignitor stock set up from a 78-79, I think. Fully electronic, very reliable, and I'm told quite waterproof. I've made such an addition to a 76 to get rid of the points. Very happy. HTH
I have a '75 with original 2F too. I'm currently running non-usa Toyota LC distributor with Pertronix Ignitor with Flame Thrower coil and MSD Offroad Ignition...I don't run the ballast or condensor but they're still there just incase.
/td
That is what I need as well...non us distributor, and an optical sensor that replaces the points as per Michael with Urban Land Cruisers...
Still have the issue witht he two wires coming out of the top of the carb...
75 with a 76 2F, 90% desmogged, just did the dizzy, go with the small cap early unit vac advance with pertronix, easy 2 wire hook up, lose the stock ignitor, carry a spare set of points in the glove box in case the pertronix fails, simplicity at its best.:cool:
One will go to the idle solenoid that is on the top passenger side rear part of the carb...follow the wires....that one must be attached to a switched 12v source, or your truck will not ever idle properly....
The other controls the power valve in the carb, iirc.
:beer:
I've got lots of spares in Helena if you want to come over the hill :D if you want to try some parts. Paul
Paul, I have ordered parts, but if this doesn't work out, I will be calling. Thanks for the offer.
Solenoid wire to switched 12v, thanks Poser, any idea on what the second wire needs to go to?
I have a '75 and I just took out the stock distributer and put in a DUI HEI ignition and MAN IS IT GREAT! I just love the thing- my engine cranks over better/faster and the engine runs a whole lot smoother than I could get it to with the stock distributer. I was posting a similar question because my ignitor was shot. I don't have any doubt that some of the other, less expensive, ignition solutions I found here would have worked; but I am really impressed with how easy the DUI was to install and, most of all, how well it performs! For me it was the right choice.
Best of Luck!
Nick
Pic of second wire
Here is a pic of the two green plugs coming from the carb... one is the idle solenoid, but what is the other? Is it necessary that this circuit is completed for the carb to run correctly? It is a desmogged engine
thanks for the help
This is not the engine, just a pic that shows the two green plugs
So as stated by Poser the fuel solenoid needs a switched 12v, but how about the temp sensor? Will the carb run without it, or does it need power as well?
are there 2 diff 40's in town? last time thru I saw a red one infront of the log house just before the turn off to town. now your pic is light green
Paul
