Ignition and vale timing
San Luis Obispo
Hello again experts,
When I got my 1971 FJ40 it sat for over 20 years. Went through all the regular stuff you do including going through the complete fuel system and fluid changes. It ran pretty good with a slight miss and low compression in 2 holes that eventually worked them selves out. The odd thing though, is the ignition timing. To get it to run decent the timing had to be advanced to about 20 + degrees. I say decent because the engine stumbles on heavy acceleration. I had read that the 2 piece cam gear can slip and sure enough when I took my engine apart the rubber between the gear parts was deteriorated. This made me happy thinking bingo I found the issue. I ended up rebuilding the engine because of a bone head move on my part not seating the dizzy in the oil pump. On inspection the cam showed some wear so I replaced it and obviously the gear too. When comparing new gear with the old one, sure enough the old gear outer toothed part had spun about 1.5 tooth. Reassembling the engine I discovered when you line the dots on the crank gear and the cam gear that puts number 6 hole on it's compression stroke not number 1. Comparing the old cam with the new it is the same also so I have no idea whats this is all about but my though is 180 off shouldn't make a difference.
Now It's all back together, well crap, same thing with the timing. It has to be timed over 20 degrees to run halfway decent. Also has the same stumble on heavy acceleration.
FYI, the dizzy is stock non vacuum advance.
Thanks
If you know the dist is 180 out. You should hook your light to #6 plug or what ever the companion cyldr is.
The dizzy isn't 180 out. What I am talking about in regard to the timing gears is when the crank gear and the cam gear alignment dots match up, that is actually hole 6 TDC fire stroke. It should be number 1 hole. Using the timing light pick up on hole 6 or hole 1 you will get the same results even if you aren't having this goofy problem I'm having.
1.Has anyone had problems with a new Toyota cam timing gear?
2. I know F.5 and F2 cams are different from a F engine in regard to the rocker are oiling. Is there anything else that's different like the woodruff key slot is clocked different?
Here's a pic from a fsm for the 2f engine. It specifically states #6 is on the compression stroke. I doubt Toyota did any major changes with timing marks thru the yrs.
What's the condition of the dist. Are the centrifugal weights free? If you twist the rotor slightly clockwise does it spring back? 20 degrees is too much. What's your total timing?
Awesome Awesome Awesome, I totally missed in the manual where it says when the marks are lined up it will be #6 compression stroke. Mystery solved on that part. Glad to find out that is by design. As far as the mechanical advance goes I think I checked that at one point to make sure it moves smoothly and snaps back but now I can't say for sure if I actually did or not. Ultimately I want a H.E.I. but not until I know this thing runs good and is dependable.
I will give the dizzy a better inspection on Tuesday.
When I had my static timing at 15 deg. advance, I couldn't get a clean start without opening up the throttle a bit.
What is your manifold vac number at your current idle?
This is what I got; Advanced dizzy to smooth out the engine and get the best vacuum reading which is just under 20 and steady. It fires right up and has snappy acceleration and the engine seems happy. But same thing this is with the timing set at 37 degrees advance and I backed that up with a second timing light just to be sure. I can set the timing to 10 deg. BTDC but the engine runs flat spits and sputters on acceleration. It makes absolutely no sense to me why 37 degrees is the sweet spot when it should barely run with that much advance at idle.
#1 and #6 are at TDC the same time. One is on the compression stroke and the other one is on the exhaust stroke. It is the cam that determines which one is which. As long as the rotor is pointing the one on compression you will be fine. If not, swap the wires on opposite sides of the cap 180 degrees apart and it will be fine.
Is your distributor centrifugal advance stuck?
You're right about #1 and #6. It's the same as 3 & 4 and 2&5. I have the rotor set to #1 as it should. Unfortunately these points don't address why it only runs well at 37 deg. advanced unless I am missing your point.
I wish I paid attention when the head was off to see when #1 & 6 were at TDC if the cam and crank timing gear marks lined up. I'm wondering if I have a F2 cam in my F engine. Anyone know if there is a difference between F engine cam and F2 cam how the woodruff key slot is clocked. If this is true, it would make my valve timing off and advancing the ignition timing to the extreme mine is compensates for it.
With vac at 20, and spark correct, it points to the carb. However, have you checked your dwell angle, or points gap? Have you read your spark plugs?
It's free and working.
Centrifugal advance is free and springs back correct. I knew the cam theory was a long shot but I am just grasping at straws now.
Dwell angle was set but I double checked and with feeler gauge yesterday. Not likely a carb issue. If it were the carb and assuming valve timing is correct advancing the timing 37 deg. Should kill the engine. 37 deg. at idle is a huge number, I shouldn't be able to accelerate without a lot of pinging. I have become convinced this definitely is valve timing. Name brand cam but who knows, maybe they have a bad batch or make um all bad. My next step is to move the timing gears off 1 tooth and see what happens. I need a radiator soon so that will be a good time to experiment.
Plugs are black and again carb is spot on dialed in and looking down the throat with throttle plate closed I get not fuel bleeding from the venturi's or pump nozzle for lack of better term. Valve timing will cause this because of incomplete combustion.
