Hello again experts,
When I got my 1971 FJ40 it sat for over 20 years. Went through all the regular stuff you do including going through the complete fuel system and fluid changes. It ran pretty good with a slight miss and low compression in 2 holes that eventually worked them selves out. The odd thing though, is the ignition timing. To get it to run decent the timing had to be advanced to about 20 + degrees. I say decent because the engine stumbles on heavy acceleration. I had read that the 2 piece cam gear can slip and sure enough when I took my engine apart the rubber between the gear parts was deteriorated. This made me happy thinking bingo I found the issue. I ended up rebuilding the engine because of a bone head move on my part not seating the dizzy in the oil pump. On inspection the cam showed some wear so I replaced it and obviously the gear too. When comparing new gear with the old one, sure enough the old gear outer toothed part had spun about 1.5 tooth. Reassembling the engine I discovered when you line the dots on the crank gear and the cam gear that puts number 6 hole on it's compression stroke not number 1. Comparing the old cam with the new it is the same also so I have no idea whats this is all about but my though is 180 off shouldn't make a difference.
Now It's all back together, well crap, same thing with the timing. It has to be timed over 20 degrees to run halfway decent. Also has the same stumble on heavy acceleration.
FYI, the dizzy is stock non vacuum advance.
Thanks
Thanks
