Idle and Fast Idle adjustment
The fast idle, circled in red, controls the idle speed when you pull the choke. That's the only time it comes into play. The idle set screw, circled in blue, controls the idle speed when the choke isn't pulled...so normal operating idle of 650. The carb has an idle mix screw but it may have the cover on it that has to be carefully drilled out...second picture circled in white. If you look down from the top of the carb, you should see it.
What are the symptoms of the current idle that you wish to address?
He pulled it and has been rebuilding it... for a bit now right @mattcheston?
