Identifying rear heater lines
Woodstock,GA
Can anyone help me identify some rear heater lines please? Need to know about what year they are off of. Also if they are bent.
Thanks,
Cimarron
Bumping this old thread instead of starting a new one.
  • Q 1: Do the earlier '40s, maybe '72 back based on info in SOR, have hard lines that go all the way to the rear heater?
In my '76, the hard lines end around where the fuel lines go through the floor (before #7 in the diagram) and there is about 18" of rubber line from there to the heater.
I've been carting around a really nice replacement set of rear heater hard lines for 10+ years. I sprung a leak and went to install them. They're really long, but maybe not as long as the pic in the OP. Sorry, no time for a pic of mine at the moment.
Maybe the same as these:
Or these:
001-jpg.1196870
They are about the right length, but I have yet to investigate if they'll work as-is. I hate to cut them down as they are about as close to new as any I've ever seen. They'd be great for a high-end resto.
In case I make up my own set:
  • Q 2a: How do you make that little bump near the end that holds the hose & clamp from slipping off?
    • Some expensive tool, I suspect.
    • Another thread I found suggests stainless with a bead welded there.
  • Q 2b: If you don't have the bump, the clamp will hold it anyway, right? Maybe a little extra rubber and two clamps?
Google bead roller. Yes you can buy an expensive tool but you can make one as well. You can double clamp and it will hold but it's the bead that prevents leaks.
Been looking at line A/C brazing recently. Silver 15 Phosphate brazing rod could likely be used to repair your old lines or create the bead you need. If need be possibly even put a ring around the new line near the end and braze it on. It’s high strength, very durable, and resistant to vibrations.
Creating a bead with a piece of copper wire and soldering it would work. Or could find a brass ferrule and soldering that on would be cleaner.
Thought it was the clamp on the smooth surface that prevents leaks. The purpose of the bead is to keep the hose from slipping off. The clamp goes just pass the bead not on it.
You are not incorrect, yes the the clamp on the smooth surface provides most the seal. It's when the hose come intake with the bead on the id and the clamp on the od that really does all the work. The clamp should be placed at the base of the bead and the the clamp should only be tightened enough to overcome surface irregularities and prevent the hose from slipping off. Take a look at a cast water pump or tsat housing, they are anything but smooth. take a look at a newer car with spring clamps notice the markings on the hose? that is for placement so that the clamp will be in the correct place in relation to the bead.
on my 10/72 there is a bit of rubber hose between the end of the hard lines and the rear heater, like this.
Not 100% certain but I think the later tubes were like this. And the early tucks didn't have hard lines at all.
