i have the Diagram 65swb sent me and figured out some more stuff. However the diagram does not incorporate a set of wires coming out of both sides of the firewall running along both aprons.
In an earier post of mine it was determined by someone that the late 1970 or early 1971 FJ 40s had a wiring set up different from most other 40s. Because it has two harnesses not just one.
I have literally about 6 different diagrams and none of them match what I have im my rig. I have found one from the factory service manual on Birfield.com. But it is too small to properly read. I dont have a computer at home. and the work computers are too locked down to blow up the PDF and print it.
I have read and heard from several people to just cut them or "its easy to figure out" Im sure it is easy when you dont have 7 extra wires and nothing to reference where they go. I am certain these are OEM wires.
I was hoping someone with the same set up would be able to say, the "pick a color" is running to this part in my truck.
The truck has been desmogged and is running a 1975 motor. so I dont know if those are where some of the wires should go. I know a few of them should go to the wipers and washer bottle. The motor runs fine and everything is hooked up to it electrically.
I have the following hooked up: Both headlights, alt, starter, all of the gauges, brake master, carb solinoid, horn relay. and a few others.
The things that are not working or not hooked up that I know of.
Both turn signals, both side marker lights in the front and the driver in the rear, washer bottle, wipers, heater fan, .
So a long explanation to a problem. I would be fine if I only had one harness coming from the passenger side, Because most of the lights and stuff terminate or end at the driver side. However I dont get a good feeling with a hand full of wires not hooked up anywhere.
I cant thank enough people for helping me out by sending diagrams and offering advise. I was simply hoping some one would be able to look at theirs and tell me where they go. I will be back to the truck tomorrow (i hope) and will write down what color combos they are.
I am sure some of these go to emmisions stuff I dont have anymore, so even knowing which ones are emissions related will greatly cut down on the number of unknowns.
Thanks again. Warren.
