For Sale Idaho- fj45 1965
Year
1965
  1. 45 Series
Mileage
6500
Color
rgb(209, 201, 194)
Asking 53000
5.7 liter LS1 fuel injected engine 305 hp, 335 fu/lbs torque
4160E automatic transmission
New Gas tank moved to rear
Be-cool aluminum cross-flow radiator with spal electric fan
Saginaw power steering box and remote reservoir
Power disc brakes (front and rear)
ARB locking differential front and rear
re-centered to Toyota bolt
pattern and offset
Spring-over-axle suspension
New Fox 2.0 shocks
Hi-Steer steering rod configuration
Flattened/smoothed firewall
Ididit column-shift steering column
Ez-Wire wiring harness
Vintage Air AC/Heater unit (ac not finished)
Sliding rear window
Classic Industries quad gauges, speedometer and clock
GM van seats modified to fit (including installation of Miata headrest speakers)
Long-bed pickup box shortened (13" front of wheel well/ 17" rear of wheel well) to fit
short bed frame
SEM color tinted bed liner applied to interior and underside
PPG paint - 2008 Toyota "Sandstorm
"° color
Looks like a cool truck but you need to post a price and some better pictures of relevant things like undercarriage, under hood, every side, etc.
Not sure how to attach more than 5 pictures but I can send some to your email. The price is at the top.
You’re limited to 5 I think if you haven’t donated. But you can just post it below, max 5 is per post, you can post as many replies as you want, each having 5 images.
Nice truck btw, I’m curious to see the engine bay. Best of luck.
Question for @wardbl …
How long is the bed?
What’s the length of the wheelbase?
I’m not super familiar with SWB 45s, and You mentioned that you shortened the bed, but the dimensions seem “off?”
My ‘63 SWB FHT bed is ~62” wide x ~69” long.
do you fill the rear tank thru the bed?
Paul,
I think this is the fill point?
Yes on the right side
The wheel base is ~103
The bed is~ 65 wide and ~ 56 long
Thanks
