Thanks for the offer John! I'm sure I'll need to pick some brains when it comes to playing with the manual choke 38 Weber that the PO installed. All in due time of course. In the meantime I need to Martack the axles, reassemble the knuckle, repair the parking brake, install the driveshafts, then measure and order my shocks. Just enough work to keep me busy for the next three weeks.
The extremely cool thing of all of this is the attitude the wife has taken towards this project. She is genuinely interested and has spent some quality time with me in the garage. She even picked the gauge layout from the three I had come up with.
I'm balancing between the wife, the kid, the dog and the 40. The dog doesn't like the 40 so much since I singed his fur while grinding. The ungrateful old bastard pissed on the tire twice already.[/QUOTE
Prolly the same spot my dog pissed on! Looks good Phil...can't wait to her run!
If I finish it?
If I finish it I won't be wheeling it. Fawk it. I quit this stupid obsession.
I'm debating on going topless on the 14th. I have the heater fan working but just need to fab up a duct to connect to the heater. I get a little pissy when I'm cold.
You allegedly have a "pair" so use them.
HEAT????? who wheels with heat????
so take the top off and wheel it!!!!![]()
too late, exactly 2 hours ago
I'll put the top on and get it tropical inside. Then when your rear end explodes because you don't have a locker, I'll drive you back to the lot.![]()
I should pay a lot more attention to that shiny head of Todd's! He called it that I had a bad ground somewhere that was killing my electrical. It turns out that the only ground I didn't check was from the battery to the frame. I was getting intermittent contact from the connection. (loose bolt) I found that out when I was moving the battery cable to a different location.
I nearly hit myself in the head for being such a dummy! You called it, I owe you a beer! Goose Island 312 or Mild Winter Ale should satisfy my tab to the cruiser god!. Since I found my problem, I picked up where I left off. She runs pretty damn well now! I got the timing on the money , I just have to dial in the Weber so I can drop the ether for start ups. I have a bit of info on that so it shouldn't be a problem!
I forgot a lesson I learned earlier in life. "Pay attention to the teacher" was left by the wayside as I've gotten older. I won't let that happen again!
Thanks Todd!
