After some searching and phone calls, I've figured out my suspension. I would greatly appreciate some input from you folks. Remember this SOA thing is new to me and I don't want to foul this up. Here's what I would like to do.
Front axle from an FJ60 cut and turned for a spring over. Then use a rear axle from the same FJ60 for the rear. I'm looking at Proffits spring outboard kit to avoid putting the spring perches too close to the diff. The only issue I'm having is deciding what spring to run. Stock 40's or stock 60's?
I also have the Saginaw conversion and will be going with the 4x4Labs Cross over kit.
Is this a legit set up?
why do you cruiser guys all use the 4x4labs setup and not a setup where the drag link and tierod are on the front of the axle. Like us minis. What makes the added stress of the 4x4labs setup worth it...?
