I must have an ABS delete
Sandy Eggo
Website
www.markkuz.com
I just started my research into this last night for all of 30 min on the 4Runner forums. After Sunday's wheeling in a sandy wash trying to keep my bosses Raptor off of my tail I had two incidents where the braking was horrible. One was at lower speeds when two motorcycles were coming up the other direction. If I would have been on the gas it could have been bad.
I miss the ABS delete with the CDL mod on my 80 series so much.
So post up if you have looked into a mod for this and if you found something or came up empty.
I will post up what I find.
I also really want to have a switch that will shut off all the electronic aids, ABS, VSC, ATRAC. I haven't had time to try yet.
I wonder if a switch interrupting power from the ABS fuse would disable ABS/TRAC/VSC without any other negative effects.
So you can just pull the abs sensor wire at any point and it will disable everything. It will throw a ABS light on the dash. People say the Master Cylinder is the easist to reach. I though the 4WD Low and Center Diff Lock disabled the ABS on the GX.. That is what I was told. In all my wheeling this summer I never had ABS engage once while in 4wd Low and CDL engaged. Don't you have a GX?
