I knew I forgot something...
Edmonton/ Fort Mac.
Just finished up putting in a Slee 6" kit and some maintenance items and wanted to see how the 37" Iroks off of my mini truck fit.
I was a little bit surprised when they started rubbing badly on the rear flare.
Turns out I forgot to put the bump stop spacers on in the rear, I am going to give them a try on some 8" rims I have kicking around with the same backspacing and see how it ends up.
Damn those are big tires ;) Looks cool though.
Looks great.. I wish I would have bought that front bumper when I had the chance!!
Is this a OEM winch?
Landcrusher80
Yes, OEM Aisin winch.
Looks like you got a TJM or similar winch bumper with an OEM winch.
Your bumper was not designed to winch with a Toyota winch.
There is no reinforcement on these bumpers; the first time you winch hard at an angle the front of the bumper will cave in.
TJM makes a winch fitment kit .... but it only works for aftermarket winches not the OEM.
I thought I should let you know.... cause I bent my aluminum bumper winching.
Take a look at the pick. BTW I was running 37's :cool:
Cheers,
Landcrusher80
Cheers,
Landcrusher80
Doing a few google searches it looks like the one I have is a Rallyspeed/Aussie Bull Bar and the un-branded bar was a listed manufacturers accessory for Toyota.
The TJM bar has the winch cable slot positioned too low to be used with the overwound factory winch, it appears to be positioned to suit a underwound winch.
Additionally the main body is considerably thicker than TJM's claimed 4mm for their 80 series alloy products, a quick check with the caliper gave me ~7mm.
However in light of the picture you posted I think that scaring up some Al HSS out of someones scrap bin and reinforcing the fairlead mount is not a bad idea.
