HZJ75 Troopy Automatic Conversion
Is the A440F the same gearbox that is in the late '80's BJ74?
* Important things that happened in 1968 ...... Wayne's 45th birthday. :D
:eek:
As far as I know, there are only two types of A440F - hydryaulic (mine) and electronic. All auto trans are hydraulic, it's just a matter of how the gear shift is controlled.
I'm sure that's how the A442F are set up as well. In terms of conversion you need to get the matching bell housing/torque converter/flex plate to match your engine and the transfer to match the trans.
Saw this in another thread.
Thought this may be helpful. 1HZ has an aftermarket conversion kit from Wholesale Automatics in OZ.
Naah, they don't dude, I've had quite a few calls with Rodney from Wholesale Automatics in Melbourne, they do transmissions and torque converters that will bolt up to a 1HZ but their conversions are for putting a 100 series transmission behind a toyota V8 diesel from the wide body. Veeeeeery expensive.
I even presented them with a technical problem with the fit that I had to engineer myself as they hadn't seen it before. (lucky my son is a fitter/machinist with access to all the gear)
I'll lay it all out with photos when I'm done. I was bolting up the whole setup yesterday and found that it did not fit under the Troopy. The train was 20mm too long with no option but to move a crossmember, so that'll be today's mission before I can continue.
Update
I'm away for work at the moment, when I get home, I'll hopefully have my mods to my HZJ75 finished and be back on the road:
Complete so far:
The next couple of weeks (head is off)
Then we'll see where we are. At 20psi, I expect it to be running very lean as there is a limit to what the 10mm VE can distribute. I'll probably go straight to the 12mm.
So, it begins...
Once I had the gearbox out I quickly realised that the A440F was the same size with no transfer case attached
New input and output shaft seals fitted to the A440F
It's a helluva lot longer with the transfer attached
Then I fitted a part time transfer spool to the transfer case
Part time transfer spool installed
As I mentioned above, there was a -16mm discrepency between the torque converter face and flex plate, so I machined the counterweight into a washer
Then had my son machine up a bush to centre the torque convertor and finish off the tolerance correction
That sorted out the spacing, but reducing the gap by 16mm means I now have to remove the 16mm (coincidence?) offset on the flexplate, I had the centre removed and rewelded, the flexplate is now at the dead centre of the ring gear
Before
After
Plus 4mm off the bolt heads (thanks Jared)
Now we're in business
Ok. time to whack it in.
First problem, it hits the fuel tank
And it hits the crossmember
Looks like I've got enough room to reposition the tank rearward and get this thing in
So I've cut out the crossmember (I'll over engineer the transmission mount crossmember to compensate - 50mm x 4mm tube) and removed the fuel tank (build new mounts for it later on so I can move it aft)
Now it fits
And I still have room to reinstate the crossmember if need be
Plenty of room
These guys did a really nice job on lengthening/shortening/balancing the shafts - $170 a pop
I cut out an inspection hatch from the backing plate so I could get access to my flex plate bolts
Tidy enough once it's all bolted up
Finally, I've got one of these
I'm covering the whole floor pan with 1 layer of Dynamat Extreme, with two layers on the tunnel
I've since finished the interior, Cloth bucket seats out of a 2014 WRX, new black carpet, black full console from an auto 80 Series cruiser, boost, EGT, trans fluid temp, intercooler water temp & AFR gauges. I'll post that next week when I get home from work.
I used a three gauge pod on the dash in front of the driver, then pulled the rear fuel tank level indicator console apart and made a new faceplate to fit two guages in there. Nearly done.
I started with this last weekend (actually it's an old photo, before I installed the 6" in line K & N setup and ditched the stock air box) but it's close
Now I've got this
I've got a busy couple of weeks coming up
Great write up pics and info.
Ive read this post to late and was going to mention i thought the cross member and tank would be in the way, its cool you worked around it.
How much did the tank have to go back , wondering if a ute would have enough cab length to allow the tank to go back if you changed it to a auto
I've got this much room to move and I needed less so I should be ok.
I haven't fabbed the mounts and put it back in yet as I'm only starting on the head tomorrow. It'll be a month until the tank is back in.
(bloody work keeps interrupting)
It won't be pretty, but it'll be strong and in ;)
