Installed a hydro boost out of an f250 over the weekend, 84 hj60, definitely a great upgrade, can lock the 35's at 60mph if desired. Should help hold it on those gnarly hills, where it always was a struggle to stop it rolling backward
what else had to be changed to do this mod? Im looking at it hard because my truck does not stop well.View attachment 1443301 fits with the standard airbox etc, later master cyl is longer and wouldn't fit, I used a later one to fab the adapter plate, as not to take the rig off the trail.
Cut the end off the input pushrod, cut thread on the rod to accept the standard clevis, shortened the master pushrod by 6.5mm, cut the factory ps pump outlet line tigged on 3/8 jic male ends onto the original steel ends and the booster piping, made up some hoses, tigged a booster exhaust fitting onto the original ps reservoir, plumbed it and done.
