- Thread starter
- #21
Landpimp...Those pictures are awesome...Do you collect Cruiser literature?...
I found a set of OEM wheels in need of powder coating for $150...Powder coating I'm guessing will be $100 for the 4?
I've read here that a new set from Dan runs around $280 for 4? Don't know what kind of finish would be on them? ...
I usually don't buy parts used if new is available...and only if it's under half price and in very good condition...
make sure they are the 75+ style/disc brake, you will find a date stamped on the wheels, also make sure they are not rivited....those are drum brake wheels
new OEM wheels are painted black and its not a durible paint job, mine chiped just between Tacoma and Gig Harbor ridin in the back of the wagon.
Cheapest in WA to powdercoat is Les Schawb(sp) at $25 a wheel, but you only have a few color choices(on is ford gray, which isnt too far off stock). Other than that most places are $35+ a wheel, some charge more to sandblast them
Powdercoating doesn't hold up so well if you actually wheel your rigs in the rocks either!![]()
The good thing about powdercoating in black is that they are a lot easier to touch up after you scratch the S@#T out of them.![]()
Best
I've got drum brakes all around? Is there a different offset on the newer wheels?...
Pimp you show off![]()
These were about $90 each to have re-worked and re-chromed. Well worth paying someone else to do it![]()
Sweet Mary...Where did you have yours done?...![]()
http://www.superiorchrome.com/
They used to look like this:![]()
Paul's Chrome wanted $250 per cap for the same job!!!
I have one brand new early cap I use for an ashtray in the shop........![]()
I have the factory 72 wheels with clips, how can I tell by looking at them if they will work for disc brake, or does someone know if they will or will not work ?
