And nothing says 'this rust was so bad that I couldn't fix it' quite as well as diamond plate.Though putting aluminum checker plate on a steel body may look good the downside is electrolysis !
I’m guessing all the stock senders were all ripped out by the po. I’d like to get a new wiring harness and put some original gauges in it. I just a kit for the exhaust, what kind of mufflers/cans are you using? Mine is LOUD how it is nowI use the stk gauge cluster with one of my sbc 40's. I just use use stk Toyota senders. I run a gm alt with an idiot light. I bypassed the ammeter. You'll need an adapter for temp sender. I bought it from Toyota. I also run rams horns, one Cruiser uses the Wagner the Y pipe then single exhaust and exits on the drivers side. The other 40 runs an exhaust shop made up Y pipe and routed the single exhaust like it was stk with 6 and exits on the pass side. The po had it done. I'll likely change it to exit out the drivers side and be less restrictive. I think I'll buy kit of bends and straight pipes and make my own.
Yeah there’s a few hiding in there and sprite and a tr6I think I'm in love with your garage......
Very nice MG too.
Correctomundo, the driveshBetter shoot us some pics of your drive shafts looks like you might have a CV joint and if so your driveshaft may be on backwards I got checkerplate on mine. I just coated the back of it with rockergaurd. Haven’t removed them in 20,years so no idea if it rusted. I put them on over new quarter panels. Lol I thought it looked good. Haha get out and drive that thing
View attachment 4120917View attachment 4120918
i just looked up budbuilt, thank you. That’s exactly what i needBudbuilt makes heavy duty 1/4 panels. I think they offer custom options also.
I run the Wagner y pipe on one of my 40's. It's quick and easy. You'll need to get the heat riser spacer for the passenger side for it to work properly. It tucks nicely under the engine. There's someone on the internet that sells a spacer blank without a flapper in it. The single exhaust is a little restrictive but works and sounds good. It can be run so it's up out of the way. Mine exits out the drivers side. My other 40 has a y pipe made by a muffler shop and is not a nice. I think I'm going to eventually get a pipe bend kit and make my own exhaust system. I'm also considering getting the 2 1/2" dump ramshorns that were on early Vettes.
I’d love a Dakota digital but it’s a bit spendy. I need to allocate my shillings to getting it driving better for now but I’ll probably do that in the endAlso give a look at the Dakota Digital guage cluster. I'm a big fan. It would solve all your issues at once, it's easy to install AND it is very well suited to a V8 swap.
Easy button, I love the sound of that. Exhaust wise this is probably what I’m going to do, thanks for the photos!Here’s a couple of exhaust runs. 2 into one with the right bank crossing in front of the oil pan on mine. Flowmaster 5117? on the first pic (mine) and not sure on the second which was done by @reddingcruiser I think. I copied him on a lot of my truck. My exhaust guy ran 3” pipe from the collector back which I wouldn’t do again. Takes up too much real estate. View attachment 4121758View attachment 4121759View attachment 4121760View attachment 4121761
Dakota Digital is the EASY button with V8s.
I had to change to a Hummer oil pan for driveshaft clearance and even with the pipe crossing in front of the sump by about 2” it was easy by disconnecting at each header and the mid-mount hanger.
I think he was referring to an LS engine when he mentioned the hummer pan.Easy button, I love the sound of that. Exhaust wise this is probably what I’m going to do, thanks for the photos!
Hummer oil pans fit on small blocks?
What’s a flapper by the way?
So Ramshorns have a dampener on them? I’m confused. I thought it just went header-to gasket-to the exhaustIts actually a heat riser. The was a dampener in the spacer that was controlled by heat sensitive spring. The dampener would close to build heat to preheat the air going to the carb when it is cold. There's a company that specializes in vettes that sells the spacer without the dampener.
Ohh got it. The spacer drops the y pipe lowerI think he was referring to an LS engine when he mentioned the hummer pan.
When I had a SBC, I used the walker y pipe. Fit well with the spacer @pb4ugo mentioned.
So the heat riser/spacer just drop the y pipe lower. This something that comes on stock sbc v8s or something ?Its actually a heat riser. The was a dampener in the spacer that was controlled by heat sensitive spring. The dampener would close to build heat to preheat the air going to the carb when it is cold. There's a company that specializes in vettes that sells the spacer without the dampener.
Yes, but just on the passenger sideOhh got it. The spacer drops the y pipe lower
