Howdy, I’m new here. Bought a fj40 and I’m looking to fix her up.
If your going to run a walker y pipe you need to run a heat riser spacer on the passenger side. It appears there are several sources for them. I also included some pic of my exhaust. Ramshorns came in 2" and 2 1/2" versions. The larger versions were on early vettes and I dont think they used the spacer, or y pipe.
View attachment 4122417Perfect, thanks for the info. I’m pretty sure I have 2” dumps so I’m just gonna stick with the horns I have
Nice 40 to start playing with, I’m just north of you up in Snohomish
So I ordered a walker y pipe 42087 from Jegs said it had it but I just tracked my order and it says the y pipe is back ordered.. everywhere else on google says it’s sold out. Seems like a pretty common part to not be available, so if anyone knows where to get one let me know
So I ordered a 42087 y pipe from jegs, it said it was in stock but apparently it’s back ordered, not sure how long that will take but I plan to call in the morning tomorrow. When I google 42087 y pipe everywhere else is sold out. Not even eBay. Let me know if you know of anywhere else
So I can’t find a walker y pipe so I’m going to make my own, can I use this Jegs reducer to bolt directly to my 2in rams horns or do I need a different style connector? I’m assuming it would work because the 2in opening on the ramshorns can dump directly into the 2.5in y pipe?
Those are collectors that bolt to 3" headers outlet. They probably won't work.
I think you need to find flanges like SMG in post 11 or @pbgbottle used. Either with a bubble or with donut gaskets like in the thread below.
Got the side panels mocked up, cleans up the rear quarters a bit, covers the holes they drilled for the round trailer lights. I’m looking for some stock taillights for my bumper I’m going to build. Is there any reason to spend 100-200$ for tail lights? I don’t need the oem connector plug, that was cut off when they put the trailer lights in the back. There’s some on eBay for 38$ with a full rubber gasket that other stock/oem ones don’t have:
I saw @SandiaFJ40 makes/made some LED lights for the fj but I don’t know where to order them. I’m willing to spend a bit more on lights if it actually matters for functionality/performance. But I don’t care if it IS original, I just want it to look like its original for the most part..
And finally no progress on the exhaust.. hopefully I’ll be starting that soon.
