This is a very good question...
ASSUMING you don't have dual batteries...
OR you do and you still managed to kill both...
Then this will NOT work for you. The reason is the starting vehicle needs to have the negative terminal connected and the dead vehicle needs to have the negative terminal grounded somewhere OTHER than the negative terminal. So wont work.
Already thinking of a solution.....
Great set-up! The only thing is that a few places like Warn already make a set up like this, however I don't know their cost.
Zack
a perko switch should do the job.
nice work joey. you should post this in the 80 section as well. they'll eat this up for sure.
Not to be a kill-joy, but:
Option No. 1
Option No. 2
Option No. 3
I like would make two suggestions:
1) Add the LED to their side of the solenoid, but make it green and properly polarized. Then also add a red LED and install it reversed polarity. If the green lights up you know that they connected their end correctly. If the red lights up you know that they did not.
2) One of these fuses for when you, or they, or both brain fade.
D'ANIMAL that's all it is. Although I don't have a winch so I needed to start from zero. Also, I wanted to be able to turn off and on. But yes, it can definitely be done on the cheap.
I got the idea while leaning against the hood of a California Highway Patrol car.![]()
Where all good ideas tend to come fromI got the idea while leaning against the hood of a California Highway Patrol car.![]()
Sure you were leaning?
And not "assuming" the position?![]()
Why only 1/0?? I would have gone bigger. Chicks dig big Cables..
I must be a red neck.
I used a pair of 4gauge jumper cables $45.00.
I cut the end off of one end and used the Glad Hands ($25.00). Glad Hands are very similar to the red connectors you have but without the cam lock mechnism.
I have my winch wired with Glad Hands ($25.00 x 2 ) in such a way that I can unplug it and plug in the jumper cables without ever lifting the hood.
For less than $150 it is done. I have two of my vehicles set up that way and will be working on the third vehicle.
