- Joined
- Apr 18, 2007
- Threads
- 103
- Messages
- 727
After reading through way too many threads about this subject, I'm looking for the definitive answer to this question:
How do you bolt a factory 1995 Toyota FZJ80 hubcentric Alloy wheel to a new Dextor non brake hub 6 x 5.5" hub?
The wheels require a shank style lug nut but the Dextor axle comes with a larger lug diameter and different thread pitch. The axle came with a set of acorn type lug nuts that you can use to bolt the wheels up after some major fiddling with bit still doesn't seem the "right" way to go. Who, what, where do I buy a shank lug nut to fit the Dextor lug from and still be able to get it centered properly? BTW, I don't want to go the spidertrax route either. I can't be the only one that has this problem....
