How to keep Mice out of your 80 series cabin
sbman
Supporting Vendor
Julian, CA
A couple of years ago, I moved to a rural area with lots of forest around our home.
Not long after, I started getting mice inside the cruiser. They would come in, chew up things and then die inside the cabin, apparently unable to get out. Yuck. Disgusting.
I searched a lot for how they were getting in, and then they started chewing parts of the air vents on the dash off and I realized how they were getting in, and why they could not get out. They were coming in the air duct at the base of the windshield, through the fan and out through the air vents into the cabin. They were unable to climb back out through the air cabin air intake, so they would end up dead in the cruiser eventually. This had to stop.
To mouse proof your 80, first remove the windshield wipers, cowling (trim piece at the base of the windshield) and the front fenders. I removed the hood to make this all easier as well. I've circled the entry point for the mice. This is the drain for the cowling area, it allows water that enters this area to drain out, otherwise it is a sealed box with grilled/vent entries at the base of the windshield. There is a snorkel style air intake in there that is where the air comes in for the HVAC system. The mice climb through the drains, up onto the snorkel, fall in and then they can't get out any way except to chew their way out through your HVAC system. There is a drain on both driver and passenger side.
The fix is to apply hardware cloth (1/4" galvanized steel mesh) to the two drains so water can get out, but mice can't get in.
Problem solved, no more mice in the cruiser. You also should make sure all of the plastic caps are in place in the body floor pan and the steering shaft boot is in tact, as those are additional places they could potentially get in.
Or you could install @Outsane Cabin Air Filter. I didn't know he followed my suggestion of adding a metal mesh to prevent mice intrusion until I saw it at Cruise Moab.
I am planning to add a cabin air filter, but I don't want mice nests up inside that cowl area at all.
Or you could install @Outsane Cabin Air Filter. I didn't know he followed my suggestion of adding a metal mesh to prevent mice infiltration until I saw it at Cruise Moab.
Order a sticker so I can send one for you.
Also keeps the crud from getting into your evap
They don't really nest there and you might cause issues with trapping debris like leaves.
Cabin Filter plus leave the HVAC in recirc mode when you park the truck.
Done. 😎
I live in the country too, and have found one of the best protections against mice, and squirrels getting inside of my truck is to invest in a few barn cats. My main protection cat almost daily leaves me a half eaten mouse, or squirrel on my door step letting me know he's protecting my truck .
Ok, I'm gonna chime in. Believe it or not I use BOUNCE dryer sheets. The original kind (no scented) I tie them to hose, wiring harness etc. Keeps them out of the engine compartment. I've had rat problems for years and this is the only thing that has been effective! Replace once a month. Im kid you not.
this is great info, thx for sharing.
Another way mice get into the cab is through the rear body holes, under the cargo area. Let me see if I can explain w/o any pics. Lay under your 80 cargo area, then look at the frame rails. You'll see square type plastic covers over one hole per side, and if one of them is missing, mice will climb in then access your cab.
I've tried the peppermint scent, Bounce drier sheets, Irish spring soap, etc but ended up with an active/electronic approach under the hood with these things: https://www.amazon.com/dp/B07MZMDY77?tag=ihco-20
Done. 😎
someone here makes these cabin air filter for our rigs, and hopefully Lee will chime in here. I wrapped mine with a metal window screen cloth to prevent rodents chewing through!
2 years ago I swiped a baby hawk from a nest in my yard and methodically trained it to stand sentry over my 80. It's working out well so far.
