Any electricians care to help me wire in my new compressor?
Is it black to black, white to white and green to green?
looks like 120volt and yes black to black white to white ibew local 26
Isnt there a switch you should be wiring to instead of the motor?
I'm no electrician but aren't 230 volt plugs supposed to be at an angle?
Like: \ . / ? I thought all 15A 120V plugs were |.| 20 A 120V are -.|...???
OK got compressor running thanks to you guys.
So now Ive got what is probably another stupid question.
The pump has a threaded hole on top that looks like it is missing something? Maybe a filer of some sort?
Any ideas?
Quick question: Is the open threaded port sucking or discharging air when the unit is running? (please exercise caution while checking, no offence meant but FOD can damage the comp and getting hurt ...well nough said)
Oif it is sucking then x2 on the inlet filter . If it "blows air" then there should be a hard line from the compressor to the air tank.
