This thread had been put on hold due to threats of extortion from Brett Young, but since extortion has gone from threat to actuality, there is no reason to accede to his demands.
So on with the show.
The engine and tranny are mated with the low miles clutch that came in the truck. It is one of the few things that was actually as advertised on this truck. The BH mounting ears, oil filter, starter, carb & P-brake are installed after the engine is in the bay.
Look out below.
From here, the tail of the trans is picked up by a floorjack to allow raising & lowering to facilitate installing the rear mounts. Once they are loosely together, the front mounts will be bolted up.
After the engine is in, the junkyard Hyundai battery is replaced with a stock Gr24 battery. Seems like a good idea to at least have a stock size battery to run the winch & aircon.
The ground battery cables are all in reasonable condition, so they are cleaned & reinstalled. The positive cable was an old parts store replacement that was almost completely burned up at the starter end. It's replaced with a proper cable and terminal.
The AC hoses were all routed wrong. This one is now positioned so the belt will not cut any further into the hose.
Underneath, the P-brake has to be rebuilt due to all the 90Wt leaving the t-case via the p-brake.
After much reconnection of heater hoses, AC hoses, fuel hoses, wiring, new oil & filter, priming of oil pump, etc, it is ready for first start:
Vroom!
That concludes restoring the engine to normal operating condition.
Next up: Bo(n)dy work.
