how much power?
Website
www.cardomain.com
Hi guys!
i have been searching for the past few hours and found just a few information. i was wondering how much power and torque can you squeeze out of the 2F engine? with all the mods done to it. i heard that theres not so much you can do to increase its power and switching to a 350 would be a wiser choice when looking for more power and torque.
Original Chevy motor was 235 ci.
Why do you need so much torque and power??
In that case you might one to get a V8 chevy.
The 6 inline Toyota FJ40 engine was designed to get you in and out of pretty much any situation. It is not definetly designed to be Hot Rod
thanks for the reply guys.. anyway, i will still have to discover the power of the 2F since my rig is still being set-up, hopefully it would run this week. i would love to have the V8, but i want it to be all toyota, im not too fond of cross breading. has anybody swaped a toyota V8 to their LC? like the 1uzfe?
Rather than higher compression pistons either change the head out (depending upon the year) or shave it.
The 1uzfe has much less low end torque than an F series engine. You'd notice a lack of power rather than an increase.
Talk to Mace. He seems to be doing well getting power out of a 2F.
You can do quite a bit, it's just pricey. Between the turbo and some of the other mods people have done, you can crank out more than double the power of stock, somewhat reliably.
MAF used to sell a Hi-Po 2f, you could call them for specs and that might give you a good ballpark for numbers.
Rezarf <><
I have a 1UZFE in my SC400 - love the engine, never had any problems with it - although I'm not looking forward to replacing the starter when the time comes. It makes enough torque to spin the tires on my 2 ton SC4 - but makes most of it's torque in the mid range. Plus it's fairly wide with its quad overhead cams - making it a tight fit in the 40. You would loose some weight up front though, as it is an aluminum block, heads, intake; and get this the 1UZFE is .2 litres shy of the 2F - so the 8 is smaller than the 6 . . .
Hypereutectic pistons are available for the 2F. Lighter than stock pistons. N/A power gains with the 2F mainly come from better pistons, porting, and balancing the rotating assy. From headers, too, but mostly @ higher rpms. Maybe someone can add to the list.
Uhhh... Higher compression, better induction, more effecient exhaust, better timing curve are just what comes to mind immediately which all produce more power than different pistons, porting or balancing. All the way down to idle and up to 6000+
All of these things in this post and in yours need to be done together for a complete power package.
Mark...
shoot a PM to BigRedFJ40 on this board.
He has a built 2F, though I am unsure the specs.
Not cheap by a longshot, but it has some pretty good snap for a 2F.
thank you guys for your inputs.. it looks to me that building up the 2F would be a deep money pit and the V8 swap is more practical when looking for more power and i love V8s. so the 350 is the easiest and most common V8 swap there is. its just that i want to keep it toyota, but toyota V8s are hard to find here and are expensive, also the parts. i guess i would have to weigh this out. thank guys!! i appreciate your help..
Just keep in mind how you plan to drive and wheel your rig. Personally I would throw the $$$ into gearing before "power". A well tuned stock 2F isn't going to win any speed contests on the street, but will surprise you off-road. This especialy with the proper gearing to match your tires.
Yep. I love a nice hot powerplant. But I am always encouraging guys to spend their money everywhere else first unless there is something wrong with the engine. Gears, tires, lockers, lift, winches, bumpers and racks and all of that sort of stuff provides a lot more satisfacftion on the trail than a hoped up engine or a swap.
Mark...
