How many months between oil changes?
SoCal
Website
www.adventurebuddies.com
97 FZJ80. Mobile 1 Synth 10w40 high mileage.
My truck is not a daily driver so it's not seeing too many miles these days. My last oil change was a little over 6 months ago, though I've put less than 3000 miles on it. Does the oil break down from lack of use? I don't want to change it just because, but I will if there is some risk to using aged oil.
I do not "think" it will break down in that time BUT you would know 100% for sure by doing a Blackstone report.
Thanks for the quick replies. That's what I suspected.
European specification on most cars with full synthetic oil is 2 years max. I certainly wouldn't be afraid of 12 months with Mobil 1.
I do my 2 Cruisers once a year with Mobil One, they only get driven approximately 9600 miles a year. I still check the oil weekly, just in case. So far, no :wrench: problems.
Miles are not the only "engine killer" in regards to an oil change. Time is also a serious consideration only because condensation in your engine introduces water to the contaminants and produces acid that attacks the weakest part which is the bearings. Filtering out the water, along with the contaminants, is the trick to getting synthetic oil and it's benefits to pay off. So realistically, you need to pay attention to time as well as mileage. The oil analysis programs that Blackstone and Amsoil
offer, for example, will give you valuable information on the condition of the oil in your engine. One other thing you can do, is run a bypass oil filter system. The one that I use is Amsoil. On mine, the bypass along with the full flow filters significantly reduce the water as well as contaminants as small as 2 microns. I change just the filters, twice a year and both the oil and filters about every 3 years. I arrived at that sequence using results from the Amsoil analysis and sampling program. I really should be doing the analysis every year, but have just gotten lazy. But, anyway, my main point is that time is just as much of a consideration as mileage for oil changes, and IIRC the disclaimer on all recommended oil change intervals includes time, as well as mileage, to avoid legal entanglements.
