How high is to high?
South Africa
My 80 has a 4" lift with 35" tires,I have allways been happy with the lift.But now am thinking of a 2" body lift.What i need to know is how high is to high? I do trips that I think would be classed with the rubicon trail.And drive +-500km to get to the trails (fully loaded) At what point do the trucks become non user friendly?
why would you want more height? larger tires?
if it dose not rub too bad with the 35's leave it! the higher you go the more off camber and hill climbs will suck, if not give you just that extra bit to roll it over!
A body lift isn't really raising COG, nor is it really helping you do anything but fit larger tires. If you are planning to go to 37's and want a bit more space between the rubber and the wheel wells, by all means.
I wouldn't hesitate to run an 80 on a 6" suspension lift - the stability is going to be more governed by how you design the suspension than a slight increase in COG over a 4" lift. The primary disadvantage of going higher will be the increase in link angles and suspension characteristics that accompany those angles, not road friendliness driving to the trail.
When we worked with the Vehicle Equiupment Safety Commission in Washington D.C., the magic number was 1.5" of additional tire/wheel width for each 1" of vehicle lift in order to buy back the lost center of gravity. This is why it's doubtful that a spring-over vehicle could ever buy back it's lost center of gravity. This doesn't have to mean anything to anybody except in a law suit!!!
good god does anyone make a 9 inch wheel spacer :p
Personally, I've seen 33" tired, 2.5" lifted 80 series trucks do some of the hardest trails out there....with no effort or intense amount of skinny pedal wheeling.
That said, a lot of what you want to do depends on the ability of the driver.
The driver, in the end, is the best judge of truck character on the trail.
As a comparison, the best driver I have seen in NM drives a stock 40 on 33's and is able to conquer everything in his path. He is the best driver I have ever seen.
Cheers.
-o-
Even with a body lift running anything larger than 35's will most likely mean cutting to eliminate rubbing.
A 1-2" body lift would be a cheap way to add more space for more travel for your 35's, but would not likely allow you to run much (if at all) bigger tires.
4 inches of lift and 35's you should be able to do most anything in front of you.
unless you are truly doing 5+ trails, and then your body on the 80 should show it.
I would not go any high unless you are trying to put a bigger tire on the truck
We have a customer with just J-springs runnin 36" TSL's and he follow our buggies almost everywhere we go.
i wouldnt add a 2" BL to an existing 4" susp lift. 1" would be fine, enough to easily clear 36's without trimming im sure. theres a point when adding too much body lift will give you negative results. all it does is allow for larger tires. the better way to add bigger tires is to slap em on, and cut whatever is in the way. of course you'd have to find optimum wheel size & backspacing to eliminate frame/susp component rub.
theres no reason a 4" lift with 35's cant eat trails like the rubicon or similar. if you're not getting through those types, maybe invest in a locker or two if you dont have any already? bigger tires are useless if they dont have traction...
Cheers.
-o-
Funny you mention him Beno. I wheeled with him in CM 05, I think. His red 40 was on the same 33's, stock suspension and drive train as well as open diffs. He went everywhere our modded, locked 80's and 4runners, etc went. I had to see it with my own eyes or I wouldn't have believed you! It was a 4 rated trail and per Rising Sun rules you had to have at least a rear locker and 33's with some lift to be able to run it. Except for him, they knew he'd be fine!:cheers:
I learned a ton from him on that day. Wheel placement and line of attack being the most important.
Not to start an argument, or get off topic, but a body lift does raise the center of gravity, although maybe not enough to matter. A 2" body lift doesn't raise it by 2" as much of the weight doesn't move up but it will raise it. Guessing how much weight is chassis bound and how much is body bound, I would say a 2" body lift would move the COG up by around 1/2" for an empty 80 and as much as 1" for one loaded with cargo (with stiff springs).
Not sure what lift mine has as I have the OME +400kg springs front and rear (I can not remember the numbers sorry), I carry a lot of weight.. I also run 35/12.5/16 Maxxis creepy clawlers with out any rubbing.
Paul
the body lift definitely impacts COG especially when the truck is loaded down with gear. He's driving 500+ miles to his wheeling destinations and emergency handling will be greatly effected with that lift and gear. He's not trailering the truck so you really need to consider every aspect of the trucks intended use when making a recommendation.
I have a 4" lift with 35s and the rears rub on full stuff against the frame. No way a body lift will resolve that. I vote stay were you are and spend the time and money on another convenience accessory or gas.
While I definatly agree that a body lift effects COG, I can say that a 1" lift makes nearly no difference, loaded or not.
When I did my 1" body lift I didn't notice a single difference in COG. On the other hand when I did my OME Medium....HUGE difference in how "tippy" it felt. (And having 2 pink panties makes it real easy to tell the difference. :) )
The body of an 80 doesn't weigh near as much as the frame/engine/drivetrain/etc. Granted when you load the 80 you're going to change the COG more, but the same holds true of loading it without the body lift.
If you want a cheap way of adding 1-2" of travel to your setup (assuming your limit is body rubbing and not frame rubbing), a small body lift is a cheap and easy way to go.
With my 315's, OME Medium (2" front, 2.5" rear), and 1" body lift I have nearly zero rubbing. By "nearly" I mean I have about a half inch rub mark at full stuff on the rear (top and center). After a few miles even that will go away. No adjusting of the bump stops was needed.
With your setup you could (theoretically) have a 1-2" shorter suspension lift, add a 1-2" body lift, and still get the same amount of travel while actually lowering your COG significantly. If you're rubbing against the frame a body lift of course won't resolve that, but there are other benefits to look at.
He's specifically talking about a 2" body lift. I personally don't see any use for a body lift what so ever if all you are going to run are 35" tires. You run in to a plethora of issues such and fan shroud alignment and so on and your center height, approach and departure angles all stay the same. But there are reasons other than practical ones to do a mod I guess.
On a rig with wheel wells this big, a body lift is really unnecessary. You can easily adjust suspension travel to fit 37's on a Slee 4" lift (which is really a 4.5" lift). Just as you can easily and effectively run 35's on a 3" lift. A body lift is really quite a bit more complicated (or at least more effort) than suspension tuning without any of the benefits that can come from that tuning.
I disagree with an earlier post suggesting you need to cut to run anything more than 35's, that is again dependent on how you design your shock travel. I could fit 36's on my lift without changing anything except shifting travel and bumpstops down 1/2" to avoid frame rubbing that I don't have now but would have with 36's, although I am flareless, and 37's are not out of reach although the tuning tolerances get very tight on a lift height as low as mine.
I understand that he's talking about a 2" body lift on top of a 4" lift. And I agree that in this situation it's going to be a largely useless mod (I doubt it'll allow him more travel as he's likely going to have frame interferance before he has body interferance). But don't discount body lifts entirely because with your setup it won't help.
There seems to be a lot of misinformation about body lifts. "Quite a bit more complicated (or at lesat more effort)" than a suspension lift? Mine took me less than half the time, and neither I nor anyone doing it had done one before (where as on the suspension lift some of the folks helping had done probably half a dozen suspension lifts between them). "Plethora of issues"? Aside from the fan shroud alignment (which is easily remedied by trimming the bushings and/or moving the mounts), there is no issues as long as you keep the lift small (1-2"). In fact there are less issues than with a suspension lift (no alignment issues, no problems with the axles being shifted, etc).
As I said before, with only the OME Medium lift I would have some serious body rubbing issues. I know that the OP has a 4" lift, but for those of us without it, a small body lift is nice to keep us from rubbing. I can't speak from experience on the 4" lift, but I can with the body lift.
As for fitting larger tires, 315's fit pretty tight for me. 36's would fit, but I'm positive that I would introduce some rubbing (turning may be tight too). 37's would be extremely tight and I'm not sure they would work well at all. This is all from a OME Medium, 1" body lift, flared perspective. Going flareless actually buys quite a bit of room, if I was flareless I'd have no problems about fitting 36's and 37's would probably work with adjusting the bumpstops down to prevent them from rubbing the top of the wheel well (or frame).
Bookilla (who had my OME Medium lift before I did) had to do trimming on his rig to fit 36's without rubbing, and even then did not eliminate all of it. He was installing the Slee 4" lift and thought he could easily fit 37's with the Slee and the trimming he did.
Anyway, all that's wandered quite a bit away from the OP's original question. As to adding a body lift on top of the 4" lift, the only purpose I would see is to increase the amount of room that he has to travel, assuming he's not already having frame interferance. If he's rubbing the frame, then it won't help. If he's only rubbing the body, then a body lift should buy him enough space to increase the travel until he can rub the frame. It would be at most a small gain, but it's not like a body lift is incredibly expensive.
So it seems that the body lift will hamper the offroading abilities.
I have the ome J springs, and no rubbing of the 35" at all.
I was wanting to find that happy medium between hard wheeling
and touring truck.
It looks like I have it at 4" lift.And by doing a body lift would put the center of gravity out and that is a con for wheeling.
It go's to show you cant have best of both worlds.:steer:
I said "suspension tuning". As in, "I have removed my flares and would like to fit 37's on my 3.5" lift, so I am going to adjust all of the suspension travel down 1" by adjusting my shock mounts and drop the bumpstops an extra corresponding inch". That is generally easier than a body lift and less expensive. Done correctly it won't introduce other issues, either.
