How do i install exhaust studs? I am doing my head gasket right now. I just got the head back from the machine shop, looks new. Some of the exhaust studs came out taking the manifolds off so i ordered all new studs and nuts. To install the new studs can i just screw in the studs to the head with double nuts? Or do i put lock tight on the studs? Any special torque specks or just something reasonable considering they are going into an aluminum head?
I also have to do the four studs that go in to the exhaust manifold and attach the manifold to the down pipe. I assume those will be about the same but might be able to be torqued higher since they are threaded into steel.
