How bad is this?
Little Canada, MN
This is my first 80 and I am a 1 :banana: mechanic. I tried waiting for the best truck I could find. I found my LX450 with only 92K on it. I have the recorded Lexus history, but there are some gaps in my knowledge of the maintenance. I am working through the baseline process.
Here is the rig.
My question right now is what should I do about this? What is the best way to clean it?
Lovely surface rust...
x2 time for a front axle rebuild. I had to tear into mine recently to get the stripped axle shafts out. Gonna have to tear into it AGAIN to put new ones in...
It gets easier the more you do it over time. Just don't pull the hub/knuckle as one unit. Real PITA to get back on properly. BTDT.
Check into stock OEM seals instead of Marlin Crawler seals..
Mine looked like this when I bought it. The axle had been rebuilt (had receipts and spoke with mechanics) but they just didn't clean up the mess.
So I soaked it in degreaser & used some toungue depressers to scoop up the grease then just wiped it all down. Leave a fresh coat for anti corrosion.
Maybe a Sandblaster!!
Well... as stated before... If you do an Axle Rebuild, you will remove all these parts and wash them clean before you re-install... I dipped mine in a bucket for about 30 minutes with some solvent or Diesel then brushed then with a nylon brush and they came out squeaky clean... well almost... :)
But If you just want to clean this up for the moment, I guess you could start by scraping them with something like a Flat Head screwdriver to get most of the heavy gunk off and then brush them with a LOT of deagreaser... Be carefull around the ABS Sensor on top so you dont damage the connector... and the tongue depressor Idea sounds good especially around the rear Wiper seal so you dont damage it more or scracth up you Diff Ball (for lack of term)
The problem is that the rear Wiper seals are probably damaged and this will happen again, and from the looks you might have a worn seal inside allowing Diff fluid to mix with your Molly grease in the knuckle creating whats called Birf Soup... which is REALLY bad on your Birfs, it will wear them down pre-maturely and they go for about $700 each (stock) so you want to take care of them.
Usually Molly grease is too thick to go past the wiper seal and build up like this, unless the wiper seal is damaged or a internal seal is allowing the thinner Diff fluid to seep in the knuckle and leak through the wiper seal, both of these conditions are bad and require an Axle Knuckle rebuild.
Anyways, with your millage you should be due for and Axle Rebuild anyways....
If you look carefully you will see a square head bolt on the top side of the knuckles... use this to veryfy if you have any grease left in that knuckle, you might be dry, make sure you add Molly grease here if you decide not to do a rebuild for the moment. Also verify your front Diff Fluid level as it may have also leaked through here and it may also need filling.
Here are a few Before and after pics of my rebuild....
This is the Driver Side Before Pic
This is the Drive After Pic
This is the Passenger Before Pic
Passenger After
X2, I have both and prefer the stock type bellows design.
I don't see birf soup, looks like normal grease seepage to me? If it were mine and there were no issues (birf clicking, etc), would clean it up, change the diff fluid, check/replenish the knuckle grease, check the arm nuts torque and drive.
This is what I would call birf soup, was cleaned ~3 weeks ago. When the seal goes bad, the gear oil leaks into the grease, thinning it and causing it to excessively leak past the wiper seals. I don't see the need to reseal the knuckles until that happens.
Kevin,
His looks like the birf soup already dried out. At least yours still have something there since it is wet.
DAMN, time for a rebuilt, not for cleaning.
If you think that there is a remote chance that you would want to do the job yourself, then wait and don't farm it out. The job that you can do is by far superior to what a shop will do. Most of the work is in cleaning old grease and the mechanic will not do this job as well as you can.
The job is intimidating and I was very nervous before I got into mine. But once you do it, it is not difficult. Don't plan on doing it in one day. Take it a part one piece at a time. As you layer it, you will find that each layer of bolts, seals, nuts, gaskets and bearings is not that complicated.
On clean-up Mineral spirits work wonders. Put some in a cheap spraybottle and use an nylon brush. You can get a 3 pack steel,brass,and nylon for less than 10 bucks. They look like a toothbrush assortment you'll need the other two for rust issues. As for the rust i've been using a product called Oshpho. Buy it at Sherwin Williams paint store 40 bucks a gallon. It will pickle the rust so it can be cleaned and painted. It smells horrible!! WARNING Oshpho WILL eat concrete and masonry so careful on the driveway.My truck came from the NE so i have similar issues.
Welcome to mud
Check that front diff too. I bought mine with 93k on the clock and the front diff was thick as pudding and looked like it hadnt been changed since the factory.
Normal seepage v. worn out axle seal: wont the front diff oil be more highly contaminated if the seal is worn out? Is this a ok way to tell how intact the seal is?
Is just filthy, if you bring your truck to Puerto Rico I know a place that do that job for $150-180.00 USD:lol: Like they said is not hard, is messy, and I did not do mine first because I found that place cheap, and I did not have the time.
Thanks for the suggestions. It is supposed to be over 20 degrees this weekend so I should have an opportunity to get out and work on it. I am going to start with a cleaning first. I read the front axle rebuild post and I am not sure if I am capable of that at this point. Maybe by the time the weather warms up my skills/confidence have improved.
Unless the front end is making "funny" noises, you can always pump more grease and wait for warm weather, If you don't mind that mess...:cheers:
I know a place that do that job for $150-180.00 USD:lol: .
now thats just crazy talk..........
how many rigs can we fit in a C-5 for a flight to Puerto Rico? U think the military would do a Group rental? :D
Let's see, you can check with the Aeroflot, they bring the Antonov 124, bigger than the C5 and is commercial once in a while, I know they can fit quite a few things inside like almost 1 million pounds. My mechanic will be busy but happy!
