How bad is this rust?
How bad is the rust?
  • Total voters
    59
the last truck I did, the LSPV bracket rotted off the frame, the end on the axle long gone along with the ebrake cable support. One of the rear sway bar mounts on the axle long gone.
I had to replace the axle housing, the entire LSPV setup, multiple brake lines and only used the torch three times.
Still need to replace the gas tank as the seem is rotted through and the tank is leaking.
If you guys in the mid west are breaking all kinds of bolts, you really should slow down and try some finesse.
and everyone has access to a MAP torch, lowes or home depot.
Have run a die over the exposed bolt threads-wire wheeled-hammering hard beforehand-hammering on smaller sockets-like to turn rh first-acetylene torch-lots of PB-vise grips-pipe wrench-among others-etc. On my plow 40 the rear shackle and pin nuts were so rusty they were a little round sleeve that a 1/2" socket maybe fit on-got them off to reuse the shackles and pins. Toyota seems to use a better grade of bolts than domestics. Harder? -to not break as easily and so many plated the plating may help them separate. SW people don't know how good they have it with this part of it. Ive taken apart SW stuff too-bolts spin right off.
The japanese do not do a good job of coatings like the Germans do. Salt eats away any japanese coating like zinc phospate and the like leaving your metal parts exposed to the elements which is what starts the rust. Look at OR and WA, they got snow and rain all the time but no rust. Because they dont use salt.
Done the "back and forth, back and forth and just when you think its free, it breaks thing" far to many times.
I like stainless steel nuts and bolts. I installed them in the cats and heat shield, after 10+ years they came apart with ease.
If I ever moved back to the rust belt, I would remove every bolt and nut exposed to the environment and douse them with anti-seize.
It is not a complete cream puff but that is really not that bad. Mine is a better than that and it spent its life in Michigan. If the body is rust free and I suspect it is, I would spend the time to change the shocks, wire wheel the accessible parts, spray some rust killer/retardant on it and use a few cans of semi black rustoleum on it. Depending upon your body condition, it really is not too bad.
Sorry man that looks like a lot of work to deal with. Maybe sell it to someone in the midwest who's idea of "normal rust" falls within this range and pick up a different cruiser from the west coast. Good luck either way.
While it would be nice to drive a rust free truck from out west(I do enjoy the lack of rust on my Tacoma from AZ. 4 winters, still 100% rust free due to protection.), there really isn't that much work here from what I can see. This truck just needs to be gone over with a wire wheel, chore boy scrubbers and Fluid Film or bar chain oil.
If you live in the Rust Belt, there aren't many vehicles of any type that last more than 2 years without getting some corrosion if the owner does nothing. This truck is 20 years old and it sounds like the body is good. If he gets the plugs out of the rockers and fills the cavities with the FF or oil and replaces them, the body can be saved. The frame and undercarriage can also be protected and if he is good about revisting them with FF and continuing to scrub the underside every spring and fall along with regular washings in the winter he can slow and even reverse much of it.
My truck is slightly more rusty underneath and my body has seen 14 far northern MN winters and I still think it's a nice truck. As long as there aren't holes or structural issues and he cleans up the bad spots, this truck has at least 10 years left in it. How long do people expect trucks to last? 30 years is a good run, for any vehicle, and this one obviously lost it's shot at becoming a beauty queen a long time ago. It's still a Land Cruiser though, I don't think they are abundant enough anywhere to be writing off any otherwise good trucks off just yet.
Just get busy with your rust prevention/ reversal and drive the snot out of the thing.
I mean, sure, if you have two weeks and can run around the west looking at a bunch of trucks and then drop $10,000 on one, go right ahead. I paid $3000 for my truck and I don't doubt that once I have all the engine and refreshment work I have going on right now done that it would sell for $6000 within a week here.
As long as we are on the subject, does anyone have some thoughts on how I can get the bolts that hold the gas tank straps off? The worst part of my truck is the skid plate and I would be happy to replace it if I thought I could safely get it off. The bolts are terrible and I am thinking I might just try to ding them off with a chisel and a hammer rather than try to use heat. I can drain the tank and I was thinking I would have it redone and replace the filler tube, but I don't want to burn the neighborhood down.
Science!
This is one of those jobs that you should start spraying with your favourite lube a week or two before getting the tools out. Then make sure you have the right tools ready. Apart from the obvious spanners and sockets, a plumbers burner, remember most lubes are flammable, unsure if you have plastic fuel lines or not? Some GOOD quality drills, not some $2.00 crap from the Chinese shop. And again some quality eazy outs, sharp centre punch, goggles, and of course your replacement bolts. I work on the basis that, if the bolt is easily accessible then don't spend to much time on it. Save that time for the bolt that is going to be difficult to get at if it breaks. Then if a bolt breaks, the trick is to get the hole in the centre, a decent punch here is good. Go for a small drill bit, make sure the drill is straight and go slowly, bringing the drill size up a little at the time.
Re the tank, if you are going to drain it, then the fumes left behind are still dangerous, if you go this route then remove the centre seats and open up the access plate in the top of the tank. Open the doors/tailgate, get a diesel car and run a pipe from the exhaust into the fuel tank. Leave the diesel ticking over. after awhile, the diesel fumes make the gasoline fume inert, and dries the tank right out, done this a number of times in the past on tanks needing mods, and I am still here.
regards
Dave
regards
Dave
Dave, I have to say that this diesel car idea is by far the most creative idea I have read on this site. How did you even begin to think to do that? I don't have a diesel car to use, but I am agreeing with your idea that I need to get all the fumes out of the tank before I even attempt this project. I think I am going to see how the winter goes and plan for a spring start date. I am very nervous about messing with the bolts and not being able to get a new plate back on. I need to take a closer look and see what type of tool angles I am going to have to work with before I buy any parts or start anything.
Im LOL ing the 20 voters that said "not to bad"..lol
Ignorance is bliss, man. If all you know is rust, this thing looks fine. I am at the point where I want to buy blown head gasket rigs and have them shipped to me so I can see more Cruisers driving around.
If anyone sees trucks that need work for cheap, but still have decent bodies and undersides, let me know. I suppose anyone would want those, no matter where they lived, but based on how all you West Coast folks laugh in our general direction as we try to keep our rusted out junk on the road, I assume people just stack rust free Cruisers up like cord wood out there. ;)
That is nothing, I would have zero issues with that. Mine is far worse and I still have no issues working on it. Just need to know how to deal with rusty hardware.
Mine is getting a full underside wire wheel and blast then repaint with por15 and a coat of fluid film over it every oil change (twice a year).
If you deal with that not you will stop the spread and have a truck that last you as long as you want to drive it.
I LOL at all the southern princesses on here that think that is bad.
I was working near a petrol refinery on Canvey Island in the UK about 30+ years ago. Only battery or diesel vehicles were allowed in i.e. no spark ignition engines. There was a guy waiting to go in with a flat bed truck, his cargo was a huge engine. I casually asked what it was for, and he explained the engine was for the tank cleaning method, so not actually my idea. A few years later I was running a V12 Jaguar Coupe, it was my DD and used for fun at the drag strip. I had trouble with fuel surge on launch, so removed the fuel tanks in the rear wings and had taken them to a garage that welds fuel tanks. Lo and behold the welder started up a truck that was sitting outside, and had a piece of flexible exhaust which clamped onto the truck exhaust, pointed the pipe into the filler of the tank and went off for a cuppa. So, later on the odd occasion I needed to work with open flame near tanks, I drained and dumped diesel fumes in there.
Now having worked with diesels now for a number of years I know that they can produce flames down the exhaust but, a) not at idle and b) only if there is something very wrong with the engine which would be obvious.
regards
Dave
I working near a petrol refinery on Canvey Island in the UK about 30+ years ago. Only battery or diesel vehicles were allowed in i.e. no spark ignition engines. There was a guy waiting to go in with a flat bed truck, his cargo was a huge engine. I casually asked what it was for, and he explained the engine was for the tank cleaning method, so not actually my idea. A few years later I was running a V12 Jaguar Coupe, it was my DD and used for fun at the drag strip. I had trouble with fuel surge on launch, so removed the fuel tanks in the rear wings and had taken them to a garage that welds fuel tanks. Lo and behold the welder started up a truck that was sitting outside, and had a piece of flexible exhaust which clamped onto the truck exhaust, pointed the pipe into the filler of the tank and went off for a cuppa. So, later on the odd occasion I needed to work with open flame near tanks, I drained and dumped diesel fumes in there.
regards
Dave
Couldn't you also just use co2? Assuming you have some compressed co2 somewhere.
Good idea but unsure how much you would have to use? As an aside, I read that under the right conditions CO2 is actually flammable, I doubt an issue here but thought I would throw it out there to add fuel (no pun intended) to the debate
regards
Dave
That rust really is t too bad, it is definitely still salvageable with some hard work. I'd start removing all the heavy flakey stuff I could with a flap disk on an angle grinder or a wire wheel and wire brushes. Once all the heavy crap is gone get a good Chem resistant spray bottle and some OSPHO and spray that stuff everywhere you can. Let it sit over night and rinse off. Allow it to dry then etch prime and chassis paint it all. Go to a DIY carwash and pressure wash out the frame rails (remove bumper to do so) Fluid film the inside of the frame rails after and I'd unplug, rinse, dry and fluid film the rockers, inside door panels and bottoms of fenders. It's not bad yet, but has the potential to go downhill fast. And I'm not sure who said the Japanese aren't good at coatings and Germans do it better...I can say I have had 2 BMW's 3 Mercedes and 2 VW's none of which were worth a damn after 7 years of meticulous care and every one of them had rust to some degree on the underside and inside door panels etc... I am a fan of older Mercedes diesels and up to the late 90's diesels but I will never again own a German car. They're great until they have a few years in them and then stuff heads south. Hell an ex of mine bought a brand new C300 a few years back and drove it almost a whole year before the power steering rack fell apart and nearly caused her to wreck. She paid the small fortune to have it repaired then sold it and bought a 2 year old s600 v12 and it blew a hydraulic line that controlled the suspension and it literally bottomed out going 70 on her way to her new job in Vegas. BOTTOMED OUT! Literally went super lowrider drug the exhaust and some other parts over asphalt at 70 and destroyed her tires and wheels. Anyway, point being, every manufacturer has their issues, Toyota suffered chassis coating issues in the 90's for sure...the t100 is a prime example...but the only one I can really think of. I went through hell grinding my chassis clean for my 3 link on my cruiser so you can't just blanket statement because those cruisers and other toyotas in the rust belt and other states that salt their roads have rust...all it takes is one rock chip to start an all out rust problem in those conditions, it's not coating and it's not junk steel it's simple chemistry/ science. Sorry for the tirade. That crap just erks me.
