How bad is this rust?
How bad is the rust?
  • Total voters
    59
Durango, Colorado
Website
instagram.com
Well, after the shop refused to install my OME suspension for the time being, i decided to take some photos of the undercarriage while it was on the lift. I knew it had some rust but this definitely isnt "minor surface rust" as the PO advertised. How bad really is it?
You may have a leak at the power steering cooler "paperclip".
every bolt you touch will snap. my frame was much cleaner than that and all the bolts broke off
doubt that if you know what you are doing. I've pulled bolts out that secured the LSPV bracket to the frame when the rest of the bracket had rotted off.
Time and patience will get it done. But if you are a brute ignorance wrencher, then yes they will likely snap.
the hardest part is getting the feel of how much force you can safely apply. Use a 6 point socket and a 3/8" ratchet. Craftman makes two lengths of ratchets and I use the shorter one so as to get a better feel of how much force I'm using.
Once the head of the bolt breaks free you will then feel the threads. So tightening the head to break it free can be helpful.
Because all the bolts tend to pass quite a ways through the frame or mount you can have a glob of rust on those threads that needs to pass through the captured nut.
Using a MAP gas torch to heat the bolt will help brake that stuff off the threads and if things are still giving you fits I use some penetrating oil but only as I work the bolt. Pre treating seems to be a waste of time. So I'll back out the bolt, spray some on what is exposed and then thread the bolt back in. Repeat this to work the lubricant into the nut.
I'd start with very accessible bolts so if you break one it's easy to drill and tap it.
I get most bolts out without heat or penetrating oil but here in the North East it's not uncommon to use it either.
I sprayed the LSPV for over 2 years. Got the nuts off in the first year. After 2nd year I gave up and yanked it off. The studs are weld rusted in the housing. Even a large hammer will not break them free. Lube, wait, beat, lube, wait, beat and nothing for my effort except dirt raining on me.
I would like to know how to get penetrating oil into places like the frame where you cant get the oil to the back side of the bolt or when the bolt head is flush to the frame and rusted to it?
Bolts on the frame are the ones I break off the most.
i grew up wrenching on midwest rigs. i know the whole working it back and forth trick. they still snap. my rear panhard is rust welded in place. my front control arm bolts are one with the bushing sleeves. fire would get them free, but not everyone has access and in the case of the bushings will ruin them. rust sucks. best thing i ever did was move away from the rust belt
Today I drilled and tapped two bolts I broke removing the slam panel last week when running 70mm cable under it.. My take on it is, if the bolt you are looking at can be hit with a drill and tap then just go for it, if it snaps drill and tap, job done. If I was going to waste time with lube, or a torch on a bolt, then I would do it on the ones difficult to get to without major dismantling.
regards
Dave
