Hot wheels
My rear rims are very hot after I drive. I even got out once and heard a popping noise. The passenger side is the hottest and both rear rims are hotter than the fronts. Anyone seen this before?
Seized caliper?
I think you guys are on the right track. I have noticed some shaking when I hit the brakes that wasn't there last week.
My vote is for brakes dragging or wheel bearings...
If my brakes are dragging, does that mean I need to rebuild the caliper or is there another fix for that?
I took apart the passenger rear break on Fri night. Sure enough, the rubber boot was torn and the caliper piston was covered with crap and seized up. I couldn't budge the piston at all. I pumped the brakes and used the hydraulic force to break it loose, took the piston out and cleaned up with brake cleaner and a wire brush. I ordered new boots and gaskets and plan to do both rear brakes this week. For now, I just put the torn boot back on so I can drive it for the next few days.
I drove about 20 miles yesterday, got out and put my hand on the rim and it wasn't hot at all so that was definitely the issue.
Thanks again for you help on this!
