Hot transfer case
Central Texas
last oil change for my t-case didn't have much on the magnetic plug, but the oil looked "metallic" in the sunlight.
Now on a trip I check the tcase temp with an IR gun and get 215f. This seems pretty hot to me. The rear diff, which is the one doing the work in my case since I'm part-time, is only 150f.
Thoughts?
Obviously I'm listening for noise. Might give a little bit of the fluid a look with clear tubing when I get to CO.
Thanks
Just a guess, but since the T case is hooked up to the transmission, and with heat being transfer between the trans, and transfer case, your reading a combined heat from the two. So at a temp of 215, i don't think you have anything to worry about.
I dont have an IR gun but mine gets super hot as well and I have new gear oil, like a week old...the U-joints at both ends of the T-case were super hot to the touch coming back from Reno as well....
Good point.
My exhaust is loud enough to make hearing minor driveline noises very difficult.. and with what the fluid looked like I'm a little edgy.
80W 90 gear oil remains stable up to 265 degrees without any problems, so if your at 215 degrees your fine. As to the glitter in your oil, anytime you have metal to metal contact, such as the gears in your transfer case, it's normal to have a little bit of fine stuff stuck on the magnet. All in all with the summer time temps now upon us, i think your temp is well within the normal range.
Thanks for the reassurance.
I'll check mine with my IR gun next time I make a trip to town and compare it to yours (will post back here).
But if your T-case (like mine) has a Viscous Coupler...it can generate some heat if your tires are of uneven diameter/pressure, or if its just getting old (silicone fluid shearing).
Also, check to see that your rear driveshaft splines can move easily (driveshaft can compress). Some folks report a 'plugged' driveshaft (when freshly greased) acting as a hydraulic ram between the rear diff and the output shaft (bearing) on the T-case, supposedly causing heat.
But...consider too....the transmission and t-case both receive heat from the engine compartment as it flows down the transmission tunnel, so some amount of heat soak is going to be present from that alone. The Tranny has a cooler, but the T-case does not. The T-case is also all gear driven....so all things combined, I would expect temps to be around 180-200ish after a long drive on a fairly hot day.
Using a passive infrared sensor requires it to target a reasonable facsimile to a black body. Aiming the gun at say shiny aluminium will give you false readings.
For reasonably accurate measuring of a shiny surface, you could stick some black insulation tape and then target that area.
Google emissivity...
cheers,
george.
No viscous coupling. He is part time 4wd.
cheers,
george.
Do you think a spot of flat black spray paint would work?
There is a 40-degree difference between my shiny aluminum oilpan and my shiny black oil filter.. so the color of the surface was on my mind.
My tcase is anything but shiny so I was trying to use some dirty grease spots.. but I'd put some paint on the oilpan too if that would work well.
In addition to heat transfer from the tranny, the exhaust is usually a factor unless routed outside the frame somehow.
A spot of black paint will work fine for getting a good temp reading.
Probably most significant is that the Land Cruiser TC is tough, very tough. Hard to hurt it unless you really try, like running it dry.
Yep, black paint is fine or basically anything that removes the 'shiny/reflective' surface - even dirty/greasy areas of the surface.
If you aim a thermal gun at a shiny surface what it actually is displaying is mostly the surrounding heat readings (even from you) reflecting off that surface. This is very obvious with a thermal imaging camera where you can 'see' the thermal gradients.
In the attached picture you can see dark/blue small rectangular areas and the larger round area top/center. Those are at the same temperature as the rest of the components except those areas are shiny metal - so reflecting the 'room' temperature (same as the left edge of the picture).
cheers,
george.
