Couple of Questions.. (THIS IS ISOTEL, Sorry Wrong Login
Im thinking it should start at the top of the small curve on the hood (39 3/4" would be the back of hood measurement), this is 1.25" in from the main body line.. Sound good??
Another one is Length of 2/3 blackout i was going to go with 30", its a bit less than 2/3. I would also put a little 2" radius on the front edge of the 2/3 ones..
The other issue is Washer nozzles.. If i make the cutouts they will have to be a little bit wide, if i don't do the cutouts you will need to remove the washers, then make your own hole with an exacto (this will look cleaner IMHO)
)Im thinking it should start at the top of the small curve on the hood (39 3/4" would be the back of hood measurement), this is 1.25" in from the main body line.. Sound good??
