I might have misunderstood what you mean by 'each terminal', but the BS 5023ST is 100A total, 30A per branch fuse block, similar to the BS 2340 mentioned by brian az above.That bus bar is sweet. Did you see this product from Blue Sea Systems? It’s the same bus bar but with 100A fuses for each terminal.
Amazon product ASIN B01HJTCNXG
ST Blade Battery Terminal Mount Fuse Block - Blue Sea Systems
Compact ATO® / ATC® fuse block consolidates branch circuits and eliminates the tangle of in-line fuses for electronics and other appliances.
Battery Terminal Mount BusBars - Blue Sea Systems
Easy to install directly to battery terminal. Tin Plated Copper battery terminal mount busbar.
Blue Sea is tip-top quality, a bit spendy. Used them exclusively re-wiring my boat. Made/distributed in Bellingham WA, 45min drive from me. A humongous variety of solid electrical products. Can't do better if rewiring your FJ. No, not affiliated in any way, just a satisfied customer.
