Build Hokie's 2003 LX470
I also noted during this that the truck needs new front brakes. Will check the rears also but seems like the fronts made it about 4.5 years which is expected given the amount of towing I did for motorcycle track days. Planning to rebuild the front and rear calipers with this brake replacement.
Well, I was under the gun doing my CV reboot the other week and now I'm paying for it. I didn't change the front diff seals and had a leak. Replaced them the other day. Fun fact, a RTIC hard can koozie is the PERFECT size to hold and drive in the seal.
In other news, the CV's are great. No more leaking. I also placed a huge order of brake parts which I'm waiting on from Toyota Decatur.
HA! Love the seal tool
Got my new steering wheel installed as part of this project. My OEM wheel’s clear coat had been chipped and broken since I bought the truck due to the PO wearing rings. The leather has only gotten worse over the years too.
This new wheel is a fantastic color match and the wood looks exceptional. Very happy with it.
Old vs. new
Where did you get the new wheel I have the same colors I need to get a new one.
Yup they got spray painted.
Hasan Khan on Facebook. More details on the last page of this thread.
I was hoping to find a company name or something i can reach out too. I dont have facebook :(
New brakes day for the front of the truck. I realized when I did my CV's that my front brakes were getting low and then after looking closer I realized I had a dragging caliper and the inner pad on the driver side was almost completely gone. After having the windows down driving, I can now hear the dragging and squealing of the dragging pad during normal driving. My front lines were also looking worse for wear so they also got replaced.
Ordered and installed the following today:
- New Toyota OEM front calipers - Not much more than aftermarket remans ($250ish at Decatur each)
- Toyota Front Brake Pads
- New Banjo bolts and washers for front brake lines
- New Caliper Bolts
- New Slee Stainless Lines F&R. I only installed the fronts today. I will do the rears later.
The rotors on the truck were barely worn and still true so they stayed put.
Old calipers:
Pad wear was really uneven:
New hotness:
Took a chance on some magnetic window screens from AliExpress after seeing the Magshades advertised on social media and thinking, yup that's a China product being resold for way too much money. I needed some shades for the baby in the backseat but also figured they'd be good for camping. I'm pretty happy with them!
The front and middle rows attach via magnets and the 3rd row and back window use these little clips to attach. The shades can easily be removed and installed and allow for the window to be rolled down which is key for me. Fitment is pretty decent too! The front windows are half size so the mirrors are usable if you wanted to keep them in while driving.
These are what I ordered
Took a chance on some magnetic window screens from AliExpress after seeing the Magshades advertised on social media and thinking, yup that's a China product being resold for way too much money. I needed some shades for the baby in the backseat but also figured they'd be good for camping. Total for all windows except the windshield was around $90 shipped and they just arrived today. The sets for only the rear windows are significantly cheaper. I'm pretty happy with them!
These fit nicely. Is this for privacy and some sun blocking? A cheap alternative to tint?
Main reason was sun shade for my 1 year old son in the back. Second reason was for privacy while sleeping in the back of the truck during track days or camping.
My HID foglights have officially bit the dust, again. The harness failed from TRS a couple years ago and they warrantied it and then the bulbs themselves were replaced shortly afterwards but the fog's don't turn on anymore. Debating replacing the HID components yet again or just switching to an LED fog light setup. I like the intensity of the HID's in the fogs but the setup has been temperamental at best.
Another item I need to look into soon is rack bushings. Getting some weird steering behavior around corners and wandering. Rack isn't leaking so no need to replace that yet. Looking at these to replace the stock ones spf2987k | Steering Rack Bushings | 98-07 Landcruiser 100 - https://www.suspension.com/spf2987k
Few updates. I found an oil leak coming out of the inspection cover on the trans. This makes me think either the RMS or the oil passage o-ring is bad. I've ordered replacements for both and need to look into how much of a PITA it's going to be to remove the trans from this truck. Likely more difficult than doing it on my 60 lol.
Also my steering bushings are SHOT. Got under the truck and had the wife row the wheel and there's a ton of lateral play. I ordered some SuperPro bushings to address that as well.
Next up is it's time for my second timing belt during my ownership. Last one was done at 183k and now I'm at ~271k. Ordered a bunch of stuff this time around to get the job done. Current list is below which has been ordered. Going to review again and see if I missed anything critical but hoping to do some items preventatively as I approach 300k that I just want to get done for peace of mind.
For anyone using this list, it's for my 2003 LX470.
ManufaturerPart #Part
AisinTKT021Timing Belt Kit with Tensioner
Denso6718184Coil Boots
Toyota16307-50012Fan Bracket
Toyota90179-06293Fan Clutch Nuts (x4)
Toyota16572-50150Lower Rad Hose
Toyota16571-50150Upper Rad Hose
Toyota90467-43002Rad Hose Clamp (x1)
Toyota90466-41008Rad Hose Clamp (x3)
Toyota90916-03100Thermostat
Toyota16346-50010Thermostat Gasket
Toyota12204-50030PCV Valve
Toyota12261-50050PCV Vent hose #1
Toyota12262-50080PCV Vent Hose #2
Toyota12236-50010PCV valve cover
Toyota90467-20010PCV hose clamps (x2)
Toyota90467-15021PCV hose clamps (x2)
Toyota32941-60290Oil Cooler hose
Toyota32942-60330Oil Cooler hose
Toyota15777-50030Oil Cooler hose
Toyota90467-20011Oil Cooler Clamps (x6)
Toyota90467-19022Oil Cooler Clamps (x2)
Toyota87248-95400Brass Heater T's (x2)
Toyota87248-60460Normal Heater T's (x2)
Toyota87245-6A190Heater T hose
Toyota87245-6A200Heater T hose
Toyota87245-6A800Heater T hose
Toyota87245-6A170Heater T hose
Toyota99556-20155Heater T hose
Toyota87245-6A180Heater T hose
Toyota87245-6A220Heater T hose
Toyota87245-6A210Heater T hose
Toyota16261-50090Water By-pass #1
Toyota16281-50030Water By-pass #4
Toyota96134-42100By-pass hose Clamps (x4)
Toyota96136-52101By-pass hose Clamps (x4)
Toyota90311-43006Front Crank Seal
Toyota90311-38065Cam Seal (x2)
Toyota96721-24025Oil Passage o-ring F&R (x2)
Toyota96761-35035Coolant Pipe O-ring
Toyota90467-16022Clamps (x4)
Toyota90467-13054Clamps (x2)
ToyotaRear Crank Oil Seal
Hokie are you still happy with your window shades? Did you also buy a shade for the windshield? My 100 is going to have to sit out for a while and needs some protection. I previously ordered a "custom" windshield screen from Covercraft and it was a complete failure; not custom at all, and it almost took an act of Congress to get a refund of my money. Thx
Yeah I like them a lot. The rear shades stay in full-time except for the rear most window. I did not get a windshield one as I have a windshield cover that I like already.
Thanks for the input!! I might risk an Alibaba purchase. I'll need a burner credit card.
