HJ47
So after way too many hours on the grinder with wire wheels, strip disc’s and air tools l finally cleaned it down and hit it with rust converter. Had a nice sliver of steel in the thumb, l don’t know why l do these things sometimes😂
Burnt out my Makita grinder in the process using the wire wheel.
Maybe someone else sandblasting and painting is the go😔
The hard work will be worth the effort when done
Mechanic gloves have saved me a lot of pain. I buy the harbor china one for cheap $7. I take ShoeGoo and coat the finger tips when they are new - makes them last several times longer. Wire wheels - super glue the wires at the hub several time before you use them - makes them last longer and helps with shedding high speed wires. Safety glasses at min, I use a full face hood and a neck scarf.
Some good tips there @charliemeyer007. I was wearing some lighter gloves when l got that splinter, went straight through. I went and got some heavy gauge mechanix gloves after that. Had wire stuck in my face using wire wheels before so try to always wear safety gear, worked many years with a one eye mate.
Poly U400 black on the chassis👍
Noticed the rear sway bar is at a bad angle and has some worn bushings.
Put that on the to do list, also want some new shocks. remember reading about rear shocks in front and longer 75 series for the rear, something along those lines anyway.
Still playing around with the tray and body heights are a bit off. Not too sure where it is exactly but check all mounts and there is some wear but maybe that’s how they are🤷🏻‍♂️ Making my OCD get triggered😂
Anyway finished painting my rear bar for the 80 series and wanted to touch up some spots on the bullbar l had been working on a while back for the HJ47.
Looking to put the spare up against the headboard rather than underneath the rear.
Also replaced the drivers side door seal as the old one was buggered and the door rattled like a bitch. Had some new door seals from cityracer but decided to use some old Hilux door seals l had instead as the door will eventually need some rust work and will be stripped down so until then these seals will do.
So much nicer with a new door seal and some softer suspension, thinking l might need to add a leaf to the front pack for some height. Not sold on the extended shackles so will just get some standard greaseable ones and see how they go.
Also need to decide on what to do for painting the headboard, rear panel infill to come.
My brother came for a visit this weekend, it’s been a long time since we caught up. Brought a heap of parts for the Beast aka FJ45 ‘77 model, has a fair bit of rust but the plan was to change points and condenser, plugs and leads and get it running. Had another carby but it doesn’t have the return fuel line on the carb plumbed in. Anyone know if this will cause an issue?
Sorted a few wiring issues and got it cranking, got spark but couldn’t get it too run. Checked valves were opening and closing, previously checked compression which showed slightly low in one cylinder but still ok. Considering checking the valve clearances🤔
Fitted the new China built carb and couldn’t get fuel in so pulled the top and found the needle and seat must have been stuck. Still couldn’t get it to run and the starter was slowly dieing😬
Moved on to the brakes and did all the front and rear wheel cylinders, still need some flexible hoses and make a few hard lines to finish but a busy few days.
Spent some more time on the old Beast. Fitted another starter motor. Still couldn’t get the new carb to take fuel in the bowl. Stripped and cleaned up the old original carb and fitted a secondhand top gasket and another accelerator pump plunger. Fitted the carb and got level in the bowl. Rechecked points gap and adjusted the valve set. Found that if you hold the ignition key all the way on it won’t get spark so had to let the key come back slightly, assuming the ignition is worn. Then finally the old 2F fired into life. Good to get another 2F back alive, love these old girls🍻
Merry Christmas
Got back onto the HJ47 after getting sidetracked, bought some steel sheet and finished off the headboard. Still needs painting.
Took the old girl for a good run to meet another landcruiser enthusiast who is building a BJ73 with a 15BFTE and 10 speed auto. This thing is going to be a beast. During that run up the highway l realised the engine is definitely lacking power and think a turbo will be in its future. Too many other things to do at the moment thou.
Mounted my Narva rear Led taillights that have been patiently waiting, had to modify the factory brackets. Then the flasher didn’t like the new LEDs. Found a thread on modifying a Toyota factory unit by removing a resistor and boom, worked a treat.
Always wanted to adjust the fuel screw to see if l could get the old girl moving a bit quicker. Anyway after catching up with a mate who builds 60 series cruisers up he mentioned he just bought a HJ60 and it flies. I called lies but decided to adjust my fuel to see what happens. Made a crude tool to loosen the lock nut and gave it half a turn. Made a huge difference and only slight black smoke on full revs. Probably should have a pyro to check but what the hell, gets along quite well now.
Finally organised my brother to come over and finish off the FJ45 aka The Beast.
Got the clutch hydraulics done, brake hard lines made and fitted the last of the flex brake hoses he got. Fired her up and the clutch works and the gearbox shifts quite nice. Fitted the fuel tank and some new fuel hoses back to the cab. Motor runs sweet considering it’s been sitting for years in a property out west and so another 40 lives again👌
Think he’s selling this one and looking to start the motor swap on his 2H troopy.
Been wanting to upgrade the light in my sandblast cabinet for a long time. It gets painful when the tear off screen protector gets worn and the rubbish fluro light could never keep up.
So l ended up with a 20” Led light bar l had and bought a 240v to 12v led controller to run it. Made sure it’s a water and dust proof one. Went with the bigger 400w.
This made a huge difference to the visibility in the cabinet. Also going to do the fine stainless mesh in front on the glass to protect it a bit more.
Next project is to do some upgrades to my 20T cheap press.
Because we all know how good the tailshaft handbrakes are l decided to go with the 60 series handbrake on the rear drums. I had the backing plates powder coated and cleaned up the handbrake mechanism. Still need to get another cable for the linkage. Brought a genuine Toyota handbrake cable from a VDJ79 as this is the one that works for the later 40 handbrake levers.
Replaced the drivers side rear bearing as it looked a bit worn, but not buggered.
Now a new problem shows up with the rear shocks interference with the new cable. I modified the lower shock mounts to be closer the the diff housing for now but the 70 series leaf spring plates are the go for clearance, l have these on my shorty. I will have to check what the BJ42 uses as it has a rear handbrake set up.
So after the backing plate install l finally got my handbrake cables, small ones inside the drums installed. Then l moved onto the VDJ79 cable install and of course it needed some mounts made. I first made the rear diff bracket that goes along the housing tube. Will need to do something for bushes here.
Then installed the lever end to find a smooth route. Then l made a bracket for the cable to route over the centre towards the cab. This utilised the factory bracket.
Now l need to mount another one up near the cab on a tray cross member. The tailshaft has been removed to remove the old cable and fix the transfer case seal weep. I suppose l should remove all the old handbrake assembly as well.
So finished off the other two mounts, first one got two bolts drilled and tapped into the cross member and the second one under the fuel tank got removed and flipped on the cable to mount to an existing hole. Worked out good considering, then stripped out the old cable and handbrake shoes. Also put a rubber plug in the adjustment hole to help seal it up. New transfer case seal and the drum cleaned up ok so it got refitted, hopefully no more leaks.
