Hitch Winch mount
sorry i been so slow to repond, y7ou can have it for $20 plus the cost of shipping, it isnt a bumper or anything just a hitch with plate to mount the winch to and provisions for fairlead and grab handles. Ill post some pics tonight.
stayalert has and ARB that he welded a 2" receiver tube to. I saw some picks of it, and I am not sure I would trust winching a 6k rig with only those welds.
My idea is to use some thing like this
and bolt it to the top of the frame. I would then incorporate it into a custom bumper.
i was also wondering if I could get this to go through a non-winch ARB. There would be a lot of added strength that could be built in.
Anything can be done. You'll be wanting to recess the winch into the bumper though- the ARB is already notable for it's crappy approach angle without a winch stuck out the front of it.
If you could figure out a way to recess a hitch mount winch, that'd be cool. Still have a crappy approach angle, though.
-Spike
Also, if you're worried about the weight factor you can kill a big chunk of the weight with a synthetic rope, it ditched about 35-40 lbs off of my winch weight.
if you get it to work, post some pictures.
I'm skeptical of the temporary-mount winches.
In my experience, if I use the winch I'll often have to use it again in a little while. The thought of putting it on the front receiver, then pulling through, then putting a muddy winch in the back, then continuing and rinse-and-repeat....
it doesn't appeal to me. But if it suits your needs, Go For It. Just take some pics so others can follow
The folks I know that use them on trails leave them on the front. They mount them on a custom bumper which keeps the winch as tight to the truck as possible. No need to move the winch unless it's needed on the rear or another truck. I would never use one either if I had to carry it in the truck.
-Spike
cool
would love some pics
I'm still trying to figure out how best to mount my X9 behind the stock bumper.... keeping it clean & tight but functional. Just need to determine how best to run the clutch lever
could you get to from one of the access holes that are on the bumper already? There is someone on here who has done this and that is how he gets to the lever.
I need to find someone who can weld me up a bumper in my area (flat central Illinois), and can help me fab this think up.
I have had a portable mount winch (8000lbs) on my older 80 series like this for four years and I found it more suitable for working condition (cutting and dragging trees around my cabin) than offroad condition (poor angle approach and vulnerable to rocks).
Regards,
Regards,
Got any pics of how it's attached to the frame?
I modified a spare 2" towing reciever frame by cutting off the bolts ends and bolt to the bottom of frame. A 3" by 3" hole was cutted out on plastic front bumper where the license plate are. Never took photo of actual connection.
That's pretty sweet. I picture a brush guard type tube in front as well. Those handles seem pretty wide apart. Not sure if I wanna carry 80+lbs like that.
When I had my 4wheel drive accesory store I sold many of this setups as a complete combo with front & rear hitch receivers, jumper cables and a Warn XD8000i winch with synthetic rope to 80 series owners who only used their cruisers once a year for off road. They were very happy to keep the winch stored in their garage when not in use on their daily drive vehicles.
Also most of them loved to use the front hitch receiver to drive their boat trailers down on the marina ramp.
Others did hunting and used the front hitch to hook a cargo carrier to stand on them, so a front receiver is not such a bad idea.
I used a universal Draw-Tite model with removable side brackets which I discarted, welded the square tube to heavy plates which are bolted to the front frame.
To get a better approach angle the actual hitch might need to be on top of the frame rails, and the mounting bracket modified for maximum clearance. Seems like it would be possible to get the angle to be at least the same as an ARB.
Yes but as I last recalled six years ago, there is no space to put on top of frame rail due to the radiator and other engine parts.
I have thought of raising mounting winch platform for a better approach but it will created an additional stress on the bolts under the frame.
...there is no space to put on top of frame rail due to the radiator and other engine parts.
There's room on mine, and I cut 2" off the ends of the frame rails. It will be a compromise- as has been mentioned before, ideally the winch would be even height-wise with the frame rails, but for approach angles this isn't practical. Mine will end up being a few inches above the rails.
-Spike
I built a pair of 2" recievers into my front bumper so as to attach a removable winch rack in the future. I made a pair for a better hold. am planning on doing a pair of recievers in the rear also with my current build. perhaps even a pair on both sides in the sliders also.
the front of my bumper is only a couple inches in front of the frame rails. as such the winch can be made to sit about the same as a permanent winch.
removable is a great option if your truck isn't dedicated wheeler. I drove around in my old bronco for years with a winch on it. used it only a handfull of times. never going to do that again. when I get back home from a trip the winch, gas can, huge spare, and highlift will go back in the shop until the next trip
I almost always go wheeling with my dad. If you always go wheeling with the same guys wouldn't it be a good idea to only have a couple winches in the whole group that could be shared? kinda like a communist wheeling club.
Anyone have any pics of the front frame with the receiver installed already?
