Hitch Winch mount
snook, that's almost exactly what my buddy had as a setup on his k5 blazer. He had marine grade electrical connectors. He would normally carry the winch inside the rig until he needed it, which wasn't often.
Anyone have any pics of the front frame with the receiver installed already?
Hitch is just under my T-15 TJM front bullbar. Receiver bolts are attached to nuts welded to the hitch to avoid any horizontal and vertical movement of any hooked accesory. At the sides are my PIAA 1500 fog lamps. Notice I use 3 holding bolts/nuts on each side of the hitch. The frame also has a steel plate on each side to reinforze it. The elastic cord hold a chain which is used together with a padlock to lock the hood and avoid any surprises when the cruiser is parked in some dangerous places.
In front of the steering shock absorber you will see part of the broken foam gasket between the A/C condenser and the radiator which one day I will replace.
Thanks for the pic. Nice set up. So, doesn't look like you can stick that behind the stock bumper.
Next thought...Do you pull anything in reverse with that set up? Should you? I'm thinking of parking a boat.
any updates or new pics of front/rear bumpers with wintches? looking into this idea and i think it will work for me and my needs
thanks
Hi I'm in the process of adding a hitch to the front to use a portable winch.
So far I've added a rear hitch receiver that is low and needs lifting up. Will do that last.
Will use the ironman winch plate that was on the front as a template to build the hitch receiver.
Thankfully I've managed to find a new bumper with a winch hole which will make my life easy.
Will keep you posted on my development....
1980 FJ 43
1982 FJ 40
1996 Fzj80
Managed to find a hitch Valley hitch receiver that is very close to the position of the hitch on the bumper opening.
So will marry it to the ironman winch platform after cutting off the parts that I don't need.
1980 FJ 43
1982 FJ 40
1996 Fzj80
Just thought to update this post seeing that I finished the project. Yippppeeeeee
'82 FJ 40
'82 FJ 40 LX
'82 FJ 43
'96 FZJ 80
